HantsCounty
- Jun 29, 2012
- 40
Hey guys, having issues with the two rear corners on my Pelican 10 ft boat. What happens is it gets dragged a little when loading, and no matter what I seem to put on it seems to rub off. The boat now fills up between the two parts of the boat making it VERY heavy. here are some pics. I have used Devcon 5min epoxy, its a two part. I have used Marine goop. Loctite 401 black max instant glue. Spray on rubber coating.......
Next I am going to try Loctite color coat. Same stuff you dip your wrenches in to get grip and to color code. Sees very strong. just unsure it will work with the boat flexing a little.. I do have a bunch of chunks of black high impact polly, if I could fasten or glue it to the boat somehow?
Thanks!!
Thanks!!
