Re: Transom Help! 1978 Jon Boat
Good day,
I am stuck for some assistance on what to do next. The welds on the end caps have broken loose, and i ended up taking the support bracket (well what was left of it) off and trimmed up alittle around the areas. I have read that you have to fabercate a new support bar, and (or) you can use L channels. What are the recommendations, or next steps that would be prefered. I am really wanting to get this boat back on the water, and was a gift to me when I left active duty service.
Welcome to iboats.
Thank you for your Service! (I am retired active duty too...... there are many of us here)
That transom is a piece of cake since it is almost 1/2 way done. Once you establish the wood inside the transom (Usually a glued together piece of 3/4" doubled up) and bolt it in using SS bolts.......... Then you can form your own transom cap from aluminum angle stock available at home depot or tractor supply. Once it is together it will be rock solid.
Here is some transom wood advice.........
Cheap but pretty
2 pieces of 3/4" exterior plywood (Never Pressure treated since the chemicals attack aluminum) and glue them together with clamps and gorilla glue over night. Cut the thick piece to proper size...... and apply 3-4 coats of exterior varnish (that's the pretty part)
a bit more money
Use fiberglass chopped strand mat and fiberglass resin to seal the wood you have glues and cut to size......
a bunch more money
Use epoxy for the gluing of the wood and coating with layers of fiberglass cloth then 3-4 coats of varnish since epoxy does not like sunlight.
When you bolt the wood...... every hole you drill needs to be coated and sealed with either epoxy or 3m5200 and use only stainless steel bolts.
The secret is to keep the plywood fully sealed up so water has no chance of penetrating.
The aluminum angle for the top is what I have used on a few including my own. No need to weld it at all.... a few bolts or screws will hold it fine. You are dealing with the cap and the transom wood is where the strength comes from.
I did one transom with 4 pieces of 3/8" exterior ply that was all laminated together with epoxy and then coated with varnish .....talk about overkill .....well I had the stuff on-hand....... and that will outlive me now.
