radgumbo
- Apr 27, 2012
- 44
Hi everyone...
I'm a newbee to boat ownership. I bought an older 1965 WARDS 14' Aluminum V-Hull in great condition. It has a 1967 Mercury Merc110 9.9 hp outboard. I've been reading all the forum questions and answers about flooring in a alum. v-hull and note the 2 main issues concerning this idea seem to be weight and center of gravity, making the boat tippy.
I saw an article where mixed expanding foam was injected through holes cut in the plywood floor panel. They were replacing a floor on what looked like an old Boston Whaler. Expanding foam can't be used in aluminum boats as it will adhere and work negatively on the rivets etc.
I was thinking that if I made my templates and cut 1/2" marine grade plywood to shape & size, then lined the bottom of the boat with a vinyl tarp or poly sheeting. I'd cut the tarp or poly to fit and run it up the sides above the finished floor level. Next, I could set my plywood down and either inject (expanding) foam or pour (expanding) foam through holes cut in the plywood floor. The tarp (or poly sheeting) would actually act as a form. This would allow the foam to cure and take the shape of the bottom of the boat but, not adhering to it. Do you follow my thinking? I could take them out afterwards and use marine carpeting and outdoor adhesive to carpet the floor....What do you think? Might this work? It would keep the weight down certainly and I could use 1/2" marine plywood. Finished floor height from the keel would be roughly 2-2 1/2"... Any suggestions or additional ideas about this possibility?
I'm thinking this might work! Let me know what you think as I really appreciate your feedback. Thanks.
~Bill
~Bill
