I am a 1967 14' V-Hull Sea Nymph. I just boat this boat a month ago, and I am teetering on completely stripping the paint and restoring the boat. It is in pretty good shape right now, mostly just has a so-so paint job on it. I have considered putting the truck bed liner in the inside and painting the outside.
When I first bought the boat, it didn't leak a drop, but after a few uses I have developed a leak around the factory install threaded floor drain. It is the type of drain that is riveted to the bottom of the boat, appears to be aluminum, and has a rounded or cupped shield on it that I have discovered is their so you can drain the boat while you are moving by removing the plug. It is cross threaded with little to no thread left and needs replacing.
I would really like to replace the drain with another aluminum drain, but I cannot find one to save my life. I don't really know what that type of drain is called. Does anyone?
I do have a 1" hole in the bottom of the floor, so I figure i might as well drain there, and not out the back...
I have found a screw in garboard drain plug and some sealants...will this work, is it the best solution?
Which sealant should I use? I bought JB Marine Weld, JB Water Weld (Putty), and Goop Marine Sealant
Should I mount this inside the floor of the boat or on the outside of the hull and use the one inch hole to be able to fit the plug?
I am open to any and all suggestions and answers. Even if they are a completely different solution. I do want to have a working drain, I will have a 15hp yamaha on this boat so turning the boat over isn't an easy option.
