Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Rust Converter on engine block??
  • Rust Converter on engine block??
    Got some chipped paint on bolt heads on engine block and mid section which have rusted a little.Could i paint with rust converter or normal paint better?
    Thanks Paul.
    "I hear and I forget. I see and I remember. I do and I understand."
    Haines Hunter V17C Half Cabin. Mercury V6 135 HP 1988.
    Re: Rust Converter on engine block??
    Thanks Paul.
    Ayuh,.... Use whatever trips yer trigger....
    I paint my motors with rattlecan Rustoleum...
    • #3
      Found out Rust Converter is not heat resistant and not suitable to use on engine.Not sure if Rustoleum kills existing rust.Is there another product that kills rust before painting on engine block.I know vinegar is always an option.
      • #4
        Your engine block does not get that hot, the exhaust does but hopefully not the block. Eastwood has a couple of products that will work for rust conversion on steel and iron. OsPho was the product of choice back in the day but I haven't seen it around for a long time. Probably an EPA issue.
        • #5
          try Rust Bullet Engine, or Por15
          1974 Bayliner 1850 Discovery w/ AQ130D Engine & Penta 270 Outdrive - SCRAPPED
          http://forums.iboats.com/showthread.php?t=519254
          • #6
            Ospho is still around. They sell in at my local ace. I live in the keys so it might be hard to find elswhere though... Rust bullet seems like it might be good stuff though. Im trying it myself but wont know for sure if its worth the money for it.
            Back to Top
