All,
I have searched the forums, and seen various responses to all, and I have a good idea on what to do to get my boat the way I want it, but I wanted a direct response because I find what I'm doing somewhat unique...
My boat is a 13' Boston Whaler, a 1958. This is the first year they've made the fiberglass 13's and this boat has a lickin so to say. Part of my project will be patching holes, forming new fiberglass structure, and filling it pitted areas.
I've seen posts on how to fix small gelcoated areas, I've seen posts that show how to paint the entire boat (after roughening up the gelcoat), but I haven't yet found how to completely get a boat water worthy when this level of repair is being done.
The bottom: I've sanded through 4-5 coats on paint, and I assume the last is the gelcoat. I've taken down to the glass in most areas because of the pits I've found. I want to do a good job sealing this boat. There are a couple wounds in which I plan on filling in with mash. So for post's sake, consider the entire bottom bare fiberglass.
The top: I haven't attacked it yet, but expect at least 5 coats of paint. There is so much orange peel on the top that I think they may have melted candle wax under the paint . I was planning on sanding down to the glass on the top as well. As I said, I want a permanent fix that is very watertight.
I'm not completely sure how to finish this boat in my own garage. I've heard that spraying gelcoat over bare glass is the way to go, but I've also heard that some have used some primer and paint, and nothing special. The latter I have a hard time believing. So I'm looking for experience here.
I have a good set of tools, but I don't have a paint booth. Not sure what to expect if I try to spray gelcoat, or the level of difficulty. I've heard paint can be rolled on, then sanded. But not sure if that works on top of bare fiberglass, what keeps this watertight?
I'm looking for advice on the bottom and the topside. I'm not a hack by any means but I want to try to do this all out of my garage. I have many years experience on cars, wood, and a number of different projects including making fiberglass wing structures. I've just never attacked the painting portions. If it takes considering an additional tool purchase to make it right, I'll deeply consider it.
I want to thank the respondents in advance, I'm sure various questions on this level have been asked before but maybe not at the full complete level of bare fiberglass on top and bottom.
Shawn
1958 Boston Whaler 13'
Shawn
