Re: Clear Gel Over Vinyl Graphics ????????
Ayuh,..... Generally speakin',.... Graphic tape goes on Top....
I realize that. Thats not what I'm asking. Can it be clear gel coated OVER TOP OF THE VINYL?????[/QUOTE]
I'm not an expert on gelcoating but I wouldn't think it would stick. Hopefully someone that's a Pro will pipe in.
Its a loaded question ..
Sure.. you can spray Clear Gel over anything.
Is the Substrate solid ? ( is your vinyl without air voids ).
You can properly prep your vinyl for gel spray ..yes..
How long will it last ? .. that is something Nobody can say unless that 'somebody' applied the graphics.. even then its hard to say given the nature of size and location of graphics.
I would probably say that unless you know how to spray Clear Gel..your clear is going to fail before your graphics.
It would probably take you more time to prep around your graphic to make sure your gel does not pop then it would be to just remove and reapply..
You would almost need to tape off the graphics and build up a few layers of clear before you start to do a full spray over the graphics. .. the edges could lift at any given point..leaving bad cut edges on your lifting graphics.
Funny thing about them solvents and stickers
YD.
