Re: can i awlgrip over my gelcoat non skid?
It doesn't look bad but I walked on it the next day. I have some dirt footprints that won't seem to come out. I dunno if its embedded into the gelcoat or what. Either way I like the glossier look anyway. So I figured a top coat of awlgrip would come out shinier and lose some of the nonskid effect
Never walk on Sprayed skid for a week
.. Gel or paint it does not matter ..
yes i walked on it with my sneakers and since i was at the boatyard the dirt from my sneakers left a footprint. i tried washing it off with some deck cleaner but it really wont come out. im thinking if the gelcoat didnt cure all the way yet that it might be embedded int the top layer. i would paint over it if i have to, maybe with awlgrip since i like the glossy look but if i can get the footprints out i would settle for that. some people reccommend awlcraft instead of awlgrip. whats the reason for that? its just for the deck
First off..the boatyard may have had someone doing a bottom sanding .. in which case you have 'bottom dust' on your boat. If you step on bottom paint dust on your boat it will stain almost Forever ! .. you will Never get it off.
Awlcraft is Spray only .. Awlgrip is more durable and is more suited to decks and skid.
You can apply Awlgrip to your gelled deck .. but I have news for you. Its going to take some TSP and some serious dewaxing on your part to get it pre-prepped for the preppers..
Best case is to sand down do a flat surface and spray/roll AG to the deck alone ..
Use GripTex ..
the awlgrip wont have a problem sticking to the gelcoat(with non skid)????
Yes it can have a problem sticking ..Its a do-over or its a cover over .. there is no basis on how well the paint sticks. For some a TSP and some Prepsol will work. Not to say it will work for your application ..but it has worked in the past ..
YD.
