Those dont look to be bases of any kind .. just the rings that were welded to the bases..
They come in different angles..
Check the Iboats ship store or West M. ..
YD.
Whoever put the bolts in, beat them over from the inside - I could not cut them off with a dremel ( not enough room )and I couldn't unscrew the nuts because the bolts were bent bad- the heads kept spinning around-I had a hell of a time trying to drill them out; 3 days. Now the screw holes are to big. I'm afraid I can't use them because the rest of the restoration will be close to show quality. All the bases I see are attached to an upright. This was a custom welded bowrail. I was wondering where I could get some new ones made - Thanks for all the help.Ayuh,... Pound them flat with a BFHammer, 'n weld 'em back onto the stanchions...
That Was a custom welded rail, before ya beat it apart...
Set-screw bases May, or may Not work for it...
