Gman 82 aquasport
- Mar 25, 2011
- 39
I have a few soft spots in the floor so it's time to tear it out and replace floor and check the foam filled stringers for water. Couple of questions about materials to use on stringers , will be using epoxy but need input on types of fglass cloth. 1708 for the stringers? with mat or not? What weight fglass cloth for bottom of floor and for top? thanks
am going to try to load a couple of pics!
If pics came thru you can see a spot on the transom on right about the size of a quarter that is soft..whats best way to fix this if it turns out to be the only bad spot..I know I won't be able to truely check the transom well until floor is out.
Fuel tank is out already..the plan is to make a larger coffin to get a larger tank ( came with 45 gallon tank, new 4/11)
