Well, here goes:
First of all, I think I will need to eventually post my thread in 3 different categories: Engine, Outdrive and restoration. But for starters, I am going to start in the restoration category since that will be my primary focus for the foreseeable future.
Moderators: Please jump in and correct me at any time. I am definitely a newbie.
I live in Gods Country: Kennewick, Washington. We are located in SE Washington. We average around 7 inches of rainfall per year. Yeah, it is dry and dusty.
I have been cruising iboats.com since early spring. Finally became a member in October 2011
I have to give credit to Trooper82 for getting me off the dime and starting my own thread. I have been following his restoration project with great interest.
I have spent the past 9 months looking for a boat to buy. I am retired, so I wanted a “project”. Not like I don’t have enough to do as it is.
Anyway, I bought 1973 Glaspy 21 foot boat with a cuddy.. It has the 250 Mercruiser inline 6 cylinders. I bought the boat and tandem axel trailer for $700.00 from a private party in Spokane, Washington.
The PO did not have a lot of information about the boat. They bought it and were going to fix it up but did not have the time or the money. I can relate to the money issue LOL.
Overall, for its age, the boat is in good condition. .It does not appear to have been abused, just neglected. Is there a difference?
The engine turns over. The compression is about 130 (give or take 2 to 4) on all 6 cylinders. If the hour meter is correct (?) the engine has approximately 2800 hours on it.
The stern drive is a MC-1 (At least that is what my research indicates. The numbers on the stern drive are 55894. The serial number on the stern drive is 3604980.
She comes with a 47 gallon fuel tank located under the deck. There is a 15 gallon fuel tank located on the left and right sides. OOPS, I mean port and starboard.
The interior of the cuddy is in good condition. All of the upholstery is in better than average condition. But OMG, I can’t stand that 1970’s green vinyl upholstery. That is definitely on its way out.
This picture was taken when my wife (Grandma) and I drove to Spokane to pick up the boat.
In the future all references to my wife will be Grandma and all references to the boat will simply be her.
As you can see from the picture, looks like someone tried to do a paint job on the bottom of the hull. Not sure what that is all about but I am certain I will find out. ..,
Overall, for its age, the boat is in good condition. .The trailer is in good condition. It does need a couple of tires replaced. But they would good enough to get me the 140 miles back home from Spokane. Down the road I plan on sanding, painting, rewiring the trailer.
This picture shows her at new her home and finally under cover. She had been sitting outside for a long time. In spite of sitting outside for I am guessing several years, the paint is in surprisingly good condition.
This next picture will probably come as a shock to most of you.
I started doing some “poking” around and guess what I found.
Can you believe that? The old girl is 39 years old and already needs a facelift. Did I say I wanted a project?
Thanks to this forum, I have a general idea of what I am facing as far as repairs are concerned. I am not the first newbie boat owner to discover this problem.
Again, thanks to this forum, I pretty much expected to find this kind of damage so therefore I was not/am not surprised.
I discovered this damage about the same time Trooper82 started his thread. That is why I have been so interested in what he is doing.
I had a boss who believed: “The devil is in the details”. He also taught me that everything has a “key”. This means things have to be done in sequence.
That is where I am now. What is the correct sequence?
I am thinking I should do the following:
Remove the seats
Remove the fuel tank.
Remove the engine
Remove the stern drive
Remove as much stuff as possible so I have a nice clean/clear work area.
This is where I will stop for today. I just need some confirmation that I am on the right track.
Remove the seats
Remove the engine
