I have an old laser sailboat with a weather worn deck. It seems to be porous, with thousands of minute cracks on the fiberglass surface. I would like to seal the surface with something that will penetrate and seal, but not necessarily build up a thick film. The original deck has a rippled surface designed to give traction and I don't want to make it slick.
I have used Imron two part paint on another boat, and have some left. Would that be a good solution? I considered spraying it on,and then wiping it off, leaving the paint in the cracks.
I have a HVLP spray system and respirator.
Any suggestions would be appreciated.
