Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
How to remove decals off the hull
  • How to remove decals off the hull
    Whats the best way to remove the OEM decals off the hull of a 97 Yamaha? I usually use a razor scraper on really small decal jobs with no issues, but I think using the scraper would damage the finish.
    Anybody done this?
    FrozenOkie -
    sigpic
    Re: How to remove decals off the hull
    I have used a heat gun, very carefully by the way. Just enough to weaken the glue. It really depends on how brittle the decals are and they glue they used. Sometimes the glue will come off with the sticker, other times it stays on the fiberglass.
    Miss Morgan,1969 Sleekcraft "Boats by Nescher" Newport. Power by Mercury 115 L6, tower of power.
    http://forums.iboats.com/showthread.php?t=364284
    Current project,http://forums.iboats.com/forum/boat-...project-fuggly
    "Nothing is done so poorly that the government can’t do it worse!"
    “It’s easy being a humorist when you’ve got the whole government working for you.”—Will Rogers
    • #3
      The best thing to use is a big rubber wheel chucked in your drill. Used it on my Waveventure and to remove striping on my searay. Heres what I'm talking about.
      http://www.shopsmartsupply.com/norto...24-p-2332.html
      Only way to go in my book.
      • #4
        from a fellow iboater smittyplugs
        The name and stripes i got off with some carb cleaner on a rag blot it over the stickers let sit then do it again and rub it off works great...
        • #5
          Sweet! But can I use a regular 3/8" drill instead of a Dremel style tool which I don't have?
          FrozenOkie -
          sigpic
          • #6
            i use a heat gun and a safety razor.....then wipe with laquer thinner......the stickers come off fast......do it at least 3 times a week.
            if you do dig the blade into the gellcoat.....just a light buff or even sand at 2000 grit and its fine
            The Hull Extension Thread
            great info on all aspects on boat building with detailed information.
            http://forums.iboats.com/showthread.php?t=234392
            IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
            IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
            November 29 2010 RIP
            • #7
              I used a 3M eraser wheel from Advance Auto on a regular drill. It worked great.
              • #8
                A hair dryer on the low setting .. peel it off very slowly.
                If you have a metallic tape .. back off the hair dryer until it works better for you.
                Yes I have had graphics that take me 1-2 hours to remove ( razors are good for nice and flat surfaces ..but not curved ones ).
                Preheat lightly infront of your removal point.
                YD.
                Do your best and caulk the rest
                • #9
                  I use the erasure wheel in my 14v cordless drill. If you haven't used one you don,t know what your missing. Truly a case of the rite tool for the job. If you get one you will never use ahead gun again.
                  • #10
                    BTW .. is this gelcoat or Paint ? PWC or Yamy boat with gel ?
                    Question for the decal removal wheel members .. with the wheel damage Imron Paint ( I already know it does not hurt the gel when used properly ) .. but what about Paint systems ?
                    YD.
                    • #11
                      Might help posting a few pictures of the letters needing removal.
                      • #12
                        we removed the lettering on my buddys truck. we removed the letters with fishing string. this left the sticky tape. we used zippo fluid and lots of fingernails.
                        2005 Chaparral 220 SSI
                        http://img.photobucket.com/albums/v4...851fba82be.jpg
                        1999 Sea Ray 180 (SOLD!)
                        http://img.photobucket.com/albums/v4...505_160633.jpg
                        1991 Sea Ray 170LT (SOLD!)
                        http://img.photobucket.com/albums/v4...27145726-2.jpg
                        • #13
                          ^Hairdryer and razor blade. Get the tape just warm enough until the blade slides under the tape. Different colors and different styles will differ in how hard it is to get off. Any residual glue, I clean off with acetone. After removal, more than likely there will be a slight color difference in the gel coat. You can wet sand this area and blend into surrounding gel coat. I used 600 grit and then 1000 wet. Then compound and wax.
                          Chris Craft 254 Seahawk
                          Visit my refurbish/upgrade project here.
                          http://forums.iboats.com/showthread.php?t=483913
                          • #14
                            The yamaha wave runners are smc with an epoxy paint. The erasrers were developed for use on auto paint so no problem. Yacht doctor you really should give them a try no skill required to use one no risk of scratching the paint like a razor and faster.
