Re: prep for awlgrip question
Actually that is not correct, BWT. MaxCor CF is specifically formulated and marketed for use in fairing systems, to which the majority volume is sold. It also has an extended recoat time that the old stuff did not have. See exerpt from the [the original MaxCor R4001/R3203] TDS below:
Plan work schedules to allow recoat/overcoating with in the four-sixteen hour window. If more than sixteen hours elapse before overcoating can occur, smooth surfaces can be abraded with a SCOTCHBRITE pad prior to recoat/overcoating. After 24 hours sand with 280-320 Grit sand paper. However, it is essential that the correct personal protective equipment is worn. Ground or sandblasted surfaces must be abraded with a grit appropriate to the surface profile before re-coating or overcoating. Due to its relatively low film thickness any significant abrading of the surface creates the need to reapply the Max Cor to have proper anti-corrosive performance.
For thin film applications Wash Primer CF should be used. It is not as film thickness sensitive as ZnCrO4, but like it can be directly overcoated with topcoat after 1-2 hours. Unlike ZnCrO4 there is no 24 hour limit, you have up to 6 months to decide what you're going to do next, and even then, just blow the settled dust, ScotchBrite it, and get on with things.
About surface prep...For Wash Primer CF, 180-220 is sufficient for direct to topcoat applications.
