Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
See more
See less
trying to replace wood trim on topside of boat
  • trying to replace wood trim on topside of boat
    so i never really worked with wood but need to replace the trim on my 14 ft fishing boat the teak thats on it is destroyed so i need 5/8 by 2 by 14 call home depot they say they dont have anything that narrow except in plywood i dont want to spend a fortune on trim what do i need to do exactly on this boat to get some trim on it
    Re: trying to replace wood trim on topside of boat
    Call up your local lumber yard ? Get some mohog or some other hardwood.
    The dimentions might kill you when you want something so small and they have to cut lumber 2" wide.
    The length is not really an issue .. its the 2" wide that will.
    Hard to come by 2"x 14' ( I am assuming 14' and not 14" please correct me if I'm wrong ).
    Scrap yards have Plenty of teak swim platforms that they are parting out .. might check into that.
    YD.
    Do your best and caulk the rest
    • #3
      Go buy some redwood at HD and some sealer. Cut it and seal it and screw it, Use ss screws.
      SMOKIN BOAT [not cause she looks good]
      88 Mach 1 Challenger,v6 205hp
      Resto http://forums.iboats.com/showthread.php?t=456745
      Gauge panel http://forums.iboats.com/showthread.php?t=495963
      Swimplatform http://forums.iboats.com/showthread....d+swimplatform
      • #4
        you can always buy the plywood and rip the pcs 2" wide your self
        New to the boating world!!! Loving learning, and restoring
        • #5
          yes 14 ft sorry and plywood im gonna say would look pretty nasty on the side
          • #6
            If you get the finished grade plywood and sand it it will look nice. Have seen and made alot of custom cabinets with it. Plus alot of people wrap the wood with vinyl anyway.
            • #7
              You should try a speciality woods shop or cabinet shop, they can make what ever you need since you don't have the tools to do it yourself.
              You may also be able to find something in the wood mouldings section of HD or Lowes. You don't have to match exactly what was on your boat, use your imagination.
              I consider overkill a job well done... plus a little extra.
              There's as many ways to do something as there is people to tell you how to do it... but not all of them are the right way.
              The drinking and debauchery will continue until morale improves... and maybe for a little while after.
              • #8
                You can PM me. I do all exotics. Shipping to the left coast may be cost prohibitive. I import a ton of Mahogany if you like red. 14' no problem
                sigpic
