bluesmoker
- Aug 8, 2011
- 6
I recently purchased a used 12' Livingston. The bottom of the inside of the hull is interesting. I will try to describe. As you likely know this boat has a w shaped hull instead of v. Inside the boat, instead of there being two two-inch wide grooves on the inside of hull that corresponding to the bottom of the twin v's on the outside of the boat, at some point a flat piece of fiberglass (perhaps 6"x10') was fit over the top of each one. This creates a hollow cavity that runs nearly the length of the boat (this covering ends just about 10 inches shy of the transom). I don't know if this is on all Livingstons or is something a previous owner did.
My issue is that this hollow space has two vent holes near the transom and it tends to collect water that is difficult to drain. I am considering stopping up the holes with epoxy or silicone but am wondering if they are supposed to serve a purpose.
Thoughts?
Thanks!
Thoughts?
Thanks!
