Getting ready to assemble this project and faced with indecision. 1977 starcraft stinger 19' fiberglass/175 johnson ob. your advice pros/cons are great!
My plan is after I sandwich my 2 transom plys together is to encapsulate them with 1.5 oz CSM and poly resin then let cure. I've learned that epoxy resin will make a better bond to poly resined glass after it has cured,sanded/prepped properly than a poly to poly bond.
So my question is when I go to place my transom to my inside hull skin(sanded/prepped accordingly) considering the back face of my sandwiched transom piece already has a layer of 1.5 oz csm,should I;
A. apply an epoxy putty(epoxy resin/chopped strand/little wood flour) to both the hull skin and opposing face of transom and then clamp it. Then filet the edges of course using the same type epoxy putty. So the transom would be encapsulated in poly,but set in place with epoxy.
Or;
B.apply a layer of 1.5oz csm to the inside hull skin using poly resin,wet out and attach my transom. This will ultimately give me 2 layers of csm between my transom and hull skin.
If I choose B, should I cut the mat to fit the hull skin or should it overlap on to the hull side walls? AND when it dries I think I should use an epoxy putty to filet the transom edges vs. a poly putty. My top layers will be epoxy/1708.
Thanks!
Or;
Thanks!
