Primitive Pete
- Jun 29, 2008
- 31
I have an old 12 gallon Sears Paint Sprayer Air Compressor. The specs are 8.1 SCFM displacement with delivery of 6.4 SCFM@40 PSI and 5.4 SCFM@90PSI. This unit has a regulator but I have no idea what the SCFM will be at other PSI settings.
Questions - How closely do the paint sprayer and compressor specs need to match? Does the 6.4@40 psi mean any sprayer that requires 6.4@40 psi OR LESS will work? What about sprayers that require 4.5@30 psi?
Looking to understand what sprayer specs will work with my compressor. Choice NOT limited to the list below but have included some examples of paint sprayers I think will work based on SCFM@a given PSI.
Have included product links if interested.
Central Pneumatic 93312 from Harbour Freight - Air requirement: 3.5 to 14 SCFM @ 10 to 30 PSI
http://www.harborfreight.com/air-tools/paint/professional-spray-gun-kit-93312.html
Astro Pneumatic AS7SP from Amazon - Air consumption: 4-12 CFM at 50-60 PSI
http://www.amazon.com/Astro-Pneumat...f=sr_1_19?s=hi&ie=UTF8&qid=1309391654&sr=1-19
Campbell Hausfeld DH3800 (HVLP) - Amazon - Air pressure 20-45 P.S.I., air requirements 3.5 to 5 SCFM.
http://www.amazon.com/Campbell-Hausfeld-DH3800-Pressure-Feed-Spray/dp/B0018S8JC4/ref=pd_sim_sbs_hi_2
Have also looked into airless sprayers listed below,
Wagner 0515022T Reconditioned Pro Coat Airless Paint Sprayer from Amazon
http://www.amazon.com/dp/B003BOYC9W...e=asn&creative=395093&creativeASIN=B003BOYC9W
Can apply latex or oil-based paint, stains and sealers with adjustable pressure up to 2800 PSI. with 0.24 GPM paint flow rate. One of the featured sprayers from the Wagner high performance series. Can draw paint directly from a 1- or 5-gallon pail. Includes 0.515 reversible spray tip for wide variety of spray situations.
Milwaukee ZRM491020 Airless/Fine Finish Paint Sprayer from Amazon
http://www.amazon.com/Factory-Reconditioned-Milwaukee-ZRM491020-Airless-Sprayer/dp/B003WJK10A
Works as airless sprayer or an HVLP fine finish sprayer. Can easily switch between airless and HVLP fine finish applications. Base is compatible with containers up to 5 gallons in size.
I will be painting a 16 foot aluminium Jon Boat that only sees fresh water. Plan to use self etching primer and Rust-Oleum paint. Marine paint is way too pricey for me.
Thanks
Thanks
