hello again everyone i have a quick question for the people WHO HAVE ACTUALLY USED STAINLESS STEEL BOLTS IN THEIR BOATS TO REPLACE BAD RIVETS . see link to boat here= http://forums.iboats.com/showthread.php?t=440708
ive done a couple of hours of searches and have found eaqual number of people saying to use them and not to use them so thought i would try to get some real world facts from you guys
well ive been working on the boat i picked up last fall (finally getting it done) and have replaced 10 rivets with stainless steel bolts and nylon/stainless nuts since the old rivets had been replaced/repaired with over size rivets..... and were bent over and installed poorly (no rebucking possible)
the others i replaced using aluminum rivets and 3m 5200 sealant......
so now to my question, again please respond only if you have used stainless bolts/nuts and tell me how long they have lasted and if you have had any corrision problems at the stainless/aluminum joint..... this boat will be usd in fresh water only and always is trailered never left in the water.
thanks in advance to any and all responses.
bass
bass
