Joe Kurland
- Jun 15, 2011
- 9
Hello everyone. My name is Joe, and I have just bought my second Snipe class sailboat (15'6"). I bought my first one in 1963 and sold it in 1973 when I moved too far away to bring it with me. My new Snipe was sitting deteriorating in a friends driveway when I discovered it and she was happy to sell it for a good price because it needs some serious repair work. Also, she had bought a Lightning.
The boat has a fiberglass hull which is in excellent condition. The decking is plywood. In some places, the varnish is peeling, there are spots where the top layer of lamination is broken off, and especially along the starboard side, the edge of the deck has warped and popped up away from where it should be attached to the ribs at the gunwales.
I'll try to upload some pictures of the damage.
I'm not sure if I can re-attach the plywood or if I need to replace it with new panels. In any case, I think that rather than varnish the wood, I should cover it with fiberglass as a more permanent solution. To do that, I'm guessing I'll need to remove the gunwales so that the fiberglass can lap over the edge of the hull for a waterproof joint, and then replace the gunwales. I don't know whether it will be possible to re-use the gunwales, or whether I'll need to replace them.
I just discovered this forum while searching for information on boat repair and am impressed with how generous this community is with time and advice. I'm fairly handy, but new to this kind of project, so I'll be taking it slowly and will probably be back with more questions as the summer progresses.
I'm not sure how to get full size pictures into the text below, but when I previewed the post, I could get full size pictures by clicking on the thumbnails.
The first picture shows the foredeck with some peeling varnish.
The second picture shows the port deck where some of the plywood is de-laminating.
This is the starboard deck which has become detached at the edge.
And this is a close-up view of the starboard deck.
Thanks in advance.
Joe
Thanks in advance.
Joe
