MaDDMike740
- Jun 11, 2011
- 1
I was given a 10 ft Jon boat it in decent shape. I want to seal all rivets and suspicious areas that may be prone to leaking. I want to sand it all down and seal it then primer it and paint it OD. I want to spray the inside bottom with the spray on bedliner to reduce noise and add traction.
My question is? What should I put on the rivets to seal them? Suggestions? What is the proper primer to use on aluminum so it doesn't peal off and what is is a good paint for the top coat?
Keep in mind this jon boat is probably old as me it just needs a little love so I'm trying to do it on the cheap cuz I dont want to drop $100 dollars on this old boat maybe $50-60?
Thank You for any help,
Mike
Mike
