Re: Building new deck onto my fiberglass jon boat.....NEED HELP!!
(Click the pic to enlarge)
Based on the above pic, the red line represents a piece of 1 1/2 x 1 1/2 strip of Douglas fir that will be attached to the hull using fiberglass mat and cloth strips. Here's how you do it.
First you will need to Kerf the wood so it will be flexible enough to make the curves. A table saw or Radial Arm saw or even a Circular saw will make short work of this. Space the kerfs abot 1/4 - 1/2" apart. Then using a R/O sander or Grinder with a backup pad and 34 or 40 grit Sanding Discs sand down to fresh glass all allong the area where the railing will be attached. When it is all sanded clean the area with Acetone. You will need approximately 1-2 gallons of polyester resin with hardener, 1 yard of 1.5oz CSM (Chopped Strand Mat) and 1 Yard of Fiberglass Cloth. You should be able to get all of this at Home Depot. It's NOT the best stuff on the Planet but will work in this case. You will attach the rail temporarily to the boat with duct tape, with the kerfs facing the sides of the hull. Then using packing tape, you will SEAL the bottom of the railing with the tape. We are going to pour the fiberglass resin into all of the saw kerfs along the top of the railing and we don't want it to leak out of the bottom. so seal it up good. When, cut a dozen strips of the 1.5oz CSM approx. 3" wide x 10" long and mix up a quart of resin with the appropriate amount of hardener. Fill all of the kerfs with resin and then
wet out a stip of the CSM and a spot on the hull an rail and "TAB" the rail to the hull in various places.(See Drawing). The resin will harden in 15-20 minutes so work FAST!
When dry remove Duct tape and fill spots where tape was. Now cut strips of CSM approx. 9" wide and as long as the piece of CSM is. You will fully encapsulate the rail in resin and CSM using the same method as you did for the tabbing. Cut the Cloth 12" strips. when the CSM is tacky NOT Dry coat it with resin and lay the cloth and saturate it with resin. When it's Dry. You now have a Permanent mounting rail that will support ANYTHING. There are short cuts but this is how I would do it if you are planning on keeping the boat long term.
