Re: 100% acrylic latex paints
Welcome to iBoats!
Yep, I recommend Rustoleum Professional Oil Based, with Valspar Hardener. My recipe is 1 qt Paint, 1 1/4 cup Acetone, 2oz of Hardener. HINT: Using the Gloss white as a Base you can use Artist Acrylic Oil Paint to Tint the paint to ANY color you want. Thin it with the Acetone and then mix it with the white to get the tint you want. I use a Harbor Freight HVLP Spray Gun with a 1.8mm tip to spray the Paint but you can use the Roll n' Roll method to apply it too!
