Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Advice Needed on Monark McFast 15
  • Advice Needed on Monark McFast 15
    Hello, I am new to this forum and would really appreciate some advice. I own a 1978 Monark McFast 15 with a Suzuki DT 50. I've had it for probably 6 years. When I first got it I had trouble with a seat base that was screwed to the deck kept coming loose for me. I just thought the scews were stripped so I used larger screws and finally put some drywall anchors in that are now loose too. I've also discoverd i have a pretty good sized soft spot around the area.
    Up to this point I had no idea how boats were constructed and that there was wood underneath the deck. Looking back it's clear now that I've got some rotting going on. I started searching the internet when I found this forum. There is a tremendous wealth of information on here and I've learned a lot. After reading some other posts I decided to check my transom. I drilled a hole close to the bottom from the inside and it wasn't pretty what came out, soggy, dark, mush.
    Like I said Ive never worked on boats before. I had pulled the outboard and started to take the rub rail off to try and lift the top off the hull. Once I started reading on here it looks like most people just cut the deck out to get to the wood underneath and then re-glass it when they are done.
    So I'm wondering, Is anyone familiar with this boat and would my original plan of taking the top off and working from the bottom up be a feasible plan?
    I've been reading a little about the seacast transom repair method. Would I be a good candidate for this?
    Or am I better off looking for another boat? I like the boat but I also don't really want to pour a ton of money into it.
    Here are a few pics. Any advice would be greatly appreciated!
    Click image for larger version
ID:	90684Click image for larger version
ID:	90685Click image for larger version
ID:	90686Click image for larger version
    Re: Advice Needed on Monark McFast 15
    Welcome to iboats Dry Dock
    You have asked a question that many have asked.....is it worth the repair cost?
    The answer is no, it's not, but very few are, it all depends on how you look at it. If you look for another boat comparable to what you have there is a good chance it will need the same repairs. If you decide to repair yours you can figure you'll spend $1,000.00 to $1,500.00. Now with that said....if you repair yours you know you have a very sound craft that will last for years to come, but you will know you won't be able to sell it and get your money back, but if you look at the price of a new rig...then hey it's a no brainer.
    Hope I have helped you in your decision.
    If you decide to repair...we are all here to help in any way we can. Oh and in in answer to your question about the top cap...yes it is much better to remove it first.
    CW
    A good brand of engine is one that runs
    • #3
      What he ^^^^said. DITTO!!! NOTE: This style of Bass boat CAN, NOT ALWAYS, but CAN SOMETIMES be a little bit of a problem in removing the Top Cap. CW might kick back in here with some pevious knowledge on the subject. The way the consoles and subdecks and livewells are constructed and attached to the hull can make it difficult in cutting free all the attachments not to mention the poured in foam that is added to the mix. These restorations can be quite daunting and effort filled. BUT... like CW said when you are done you will have a boat that will probably be BETTER than it came from the factory and will last as LONG as you want to keep it with NO more ROTTING issues to bug you. And with the costs of new rigs you WILL Save a TON of money in the long run if you want to put the time and effort into it. WE WILL help you with any issues that arise. If you decide to move forward, post more pics and start askin dem questions!!!!
      1961 Lonestar Flamingo - SPLASHED...Kinda!!
      Fabricating Decks, Stringers, and Transoms
      Paint Your Boat with Tractor Paint...Say What!!!
      • #4
        Thanks for the advice guys. I see I will need to make a decision one way or the other. On one hand i'm not really keen on spending that much money on a boat this old but your point about buying another used/new boat is well taken. I enjoy challenging projects like this the only issue right now is finding time to do it. I'm thinking about trying to pull my top cap off and seeing what I run into. I'm sure if I decide to go ahead with it I'll have more questions.
        • #5
          After thinking about it some more I think I'm going to dive in. I finally got the top cap off last night. I ended up spending most of an evening getting the rub rail off. It was held on by regular steel screws and a lot of the heads were beyond grabbing a screw driver. I'll definiately use stainless screws when putting it back on!
          Here are a few pics of the project thus far
          .Click image for larger version
ID:	91434Click image for larger version
ID:	91432Click image for larger version
ID:	91433Click image for larger version
          A few of the pics show where the main soft spot was on the deck. There was a piece of foam underneth that I was able to just pull off. It looks like there is an extra strip of ply 12-14 inches wide running down the middle. I'm assuming this is for extra support. I will now need to do some more home work to know how to proceed. Can anyone recomend any threads that have some basic glassing how to's for a beginner like me? I need to learn more about tools, supplies, etc. Hopefully this weekend I'll find some more time to search the forums.
          • #6
            I really Like the idea of using Seacast on my transom because I wouldn't have to worry about it rotting again but after figuring up the cost I started rethinking. Since I'll need to learn how to glass anyway in order to fix my deck and I have everything pulled appart for easy access I'm guessing I could get by a lot cheaper by laying up a tradtional ply transom. The boat is 32 years old so If I can get another 20 out of it hey, not bad. THe transom is laid up with a piece of 1/2" and a Piece of 3/4" making it 1 1/4" between the skins. It also has a brace along the inside. See pics
            One question I had, I have a bunch of unused holes in my transom, Kicker bracket, old screw holes, different outboard etc, I had been thinking the seacast would fill these nicely. I'm assuming there is an easy way to fix/ fill these with epoxy or somthing?
            Again I will need to start searching transom repair threads. Here are a few pics
            • #7
              Congrats on deciding to fix her up and welcome to the madness. Those early bass boats are great rigs and I think yours will fix up very nicely. Done properly, your rebuild will easily be WAY better than how the factory originally constructed it so it will definitely last you for many many years. In my opinion, your boat wasn't a good candidate for SeaCast anyway. Again my opinion only, but I think SeaCast is excellent for one main purpose: replacing the transom in an otherwise solid boat. Dig out the old transom with an electric chainsaw, pour in the new transom, done. With yours having deck and stringer rot which necessitated the removal of the cap, you're better off saving your pennies and doing a plywood transom. Properly sealed it will last as long as you need it to. As for your extra holes, with your new transom providing a backer, the holes in the skin can easily be filled with some thickened resin or other type of filler. The glass guys (which I am not) can better guide you on that. Good luck with your project.
              1976 18' Starcraft SuperSport 90HP Evinrude
              Restoration thread http://forums.iboats.com/showthread.php?t=357767
              1966 16' Starcraft Jupiter 85HP Johnson
              Restoration thread http://forums.iboats.com/showthread.php?t=338633 sold
              • #8
                Finally got her flipped over and I'm working on getting the old deck out. It was a lot worse than I expected, mostly crumbled out. I've run into an issue I need some advice on. My boat has a rod locker along one side, The sides of it are ply and it obviously was put in after the deck was glassed in. I'm assuming I'll be wrapping the glass down over the side a little to tie the new deck in. Well this thing will prevent me from doing it along the one side. What I did was cut the old glass a couple of inches from the edge planning to try and work the old ply out from underneath and then pushing the new ply back in underneath and just tie the glass into the lip I left. Of course this is the only piece of deck on the boat that is still somewhat solid so It's going to be a lot of work to get it out this way but I think I can do it. I just want to make sure my plan is feasible before I go to all the bother. I don't really want to cut the locker out if I don't have to but let me know what you guys think. I've attached a few pics to try and help show what I'm talking about.
                • #9
                  A little update, I've been rather busy the last few weeks but have been working on the boat whenever I had a chance. I picked up some Marine ply for the transom at the local lumber yard, the deck was 3/8" ply. They didn't have any marine ply in that thickness so I just got a piece of exterior grade. My glass supplies came in the other day. I got some 1.5oz CSM, 1708, 5 gal of resin, some cabosil, glass bubbles, 1/4" chopped strand to make PB. And then some rollers, brushes, mixing cups etc. And also some pour foam.
                  I'm ready to try my hand at some glassing! If I ever get done sanding that is.
                  I've got the under side of the deck pretty well sanded down and cut some of the plywood. There will need to be a seam in the ply, I left it in the same place it was, on top of the 10" wide piece of 3/4" that runs down the middle. I'm thinking about gluing everything together with Titebond III before I Wrap it with a layer of CSM. Or should I wrap all the pieces individually? I'm attaching a drawing and some pics for reference.
                  My next question is how should I attach my new deck to the deck skin i left on? Should I use thickened resin? I'm planning on wrapping the ply with CSM before I attach it to seal it. I'm just not sure yet how I'm going to attach it and how I'm going to clamp it together.
                  • #10
                    Just thinking, do I even need to attach my new deck to the old skin?
                    my plans are to cover the bottom of the deck with a layer of csm folowed by a layer of 1708 and another layer of CSM wrapping them down over sides to tab it in. With my console in there and my seat base in the middle I don't think it will move much. Or maybe I should just put a few beads of PL premium here and there? Any advice?
                    • #11
                      Time for an update. I got quite a bit done this last week, My dad was down to help me the other night. We hoisted the top cap up off the dolly it was sitting on, I got a piece of 1/2" OSB which I cut to fit up underneath my upside down top cap, we then placed about 5 stacks of cement blocks underneath this then let the cap down on top of this. Now my deck skin was nice and solid since I had something to push against. I decided to attach my new deck with thickened resin. I had glued the new deck together with Titebond III and wrapped it with a layer of CSM. This morning My brother in law helped me and we gave it a coat of PB then clamped everthing down as best we could.
                      • #12
                        And now for the ugly part. While my deck was curing today I brought my hull in from the barn and started grinding the transom down to get it ready for replacement. I was grinding along the bottom of the hull when I discovered more wood, it looked like balsa (I fly model airplanes so I recognized it). Click image for larger version
ID:	94880Click image for larger version
ID:	94881Click image for larger version
                        I then drilled a few holes and discovered that there was a layer of balsa underneath what I thought was the hull. some of the shavings were clean but some were rotten. I went ahead and finished grinding out for the transom replacement then I cleaned up and headed for Iboats.
                        It didn't take me long to find "balsa cored hull" Now what to do, I've put quite a bit of time and money into it already but from what I read re-coring a hull is beyond what I want to get into.
                        I noticed one area that seemed soft when I stepped on it. It was one side of the wide curved layups that runs up into the bow.
                        Will this weaken my hull in that it would be dangerous or does it just make it heavier? Do I have any options at this point? Needles to say I'm felling pretty discouraged right about now!
                        • #13
                          Sorry to bump this again but I really need some advice on how to proceed. Since I discovered I have a balsa cored hull and at least some of it is wet/ rotten does this pretty well give it a ticket to the dump or is there something that can be done? From the threads i found with this problem it didn't sound too hopeful.
                          Thanks in advance for any help,
                          Steve
                          • #14
                            Can you determine the extent of the wet balsa? By drilling into it is it ALL wet or just an area?
                            • #15
                              I only found one area that was really bad. In front of the transom it was discolored but it still seemed pretty solid. I'll do some more test holes.
                              Back to Top
