Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
1981 "SpaceCraft Boat Works, Miami FL" 23.33ft 4100lb V240 Super Sport
  • 1981 "SpaceCraft Boat Works, Miami FL" 23.33ft 4100lb V240 Super Sport
    I just procured this boat, it had been sitting for some time and was bought from probably the original owners. I traded a 1996 1100zxi 2-seater kawasaki jetski for it.
    IBoats reference on this model
    http://www.iboats.com/Spacecraft__Su.../bp/62b83951r2
    Info on OMC Stringer sterndrive that this boat has (1981 mechanical shift variant)
    http://www.glmmarine.com/30yearsomc.html
    Phase 1:
    http://www.flickr.com/photos/6284449...7626594681785/
    Phase 2: (After dry cleaning with shop vac)
    http://www.flickr.com/photos/6284449...7626613989795/
    Phase 2.5: (Ford 302)
    http://www.flickr.com/photos/6284449...7626770428942/
    Phase 3: (After wet cleaning with bleach / degreaser)
    http://www.flickr.com/photos/6284449...7626777954802/
    Phase 4: (Outdrive removal, and old engine removal)
    http://www.flickr.com/photos/6284449...7626766206685/
    Phase 5: (Transom Replacment)
    http://www.youtube.com/watch?v=h65RL__Madc
    http://www.flickr.com/photos/6284449...7627010042592/
    http://www.youtube.com/watch?v=C3yfB...el_video_title
    http://www.youtube.com/watch?v=X4Of8pa7MOU
    Engine Running!: (PRIOR TO DISCOVERY OF CRACKED CYLINDER)
    Engine re-assembly after machine shop visit for a new block:
    Engine installation into boat:
    Outdrive Installed:
    FIRST RUN!!!
    I'm excited about this project for a few reasons.
    1. This is my first boat
    2. Spacecraft Boat Works is a very well known company in florida, but hardly known of elsewhere since their closure in 1991 (or 1993?) (along with a great many other boat companies at the time). I am very excited to be bringing one of these back to life.
    They used to make the fiberglass nosecones used in the Space shuttle until they lost the contract and as a result began making boats.
    3. Boats made of all fiberglass are EASY to clean / restore and bring new life back too due to no wood rot issues to deal with. I am finding this to not necessarily be true though due to the transom having wood.
    EDIT: The entire transom had to be replaced, so that wasn't true at all.
    EDIT: You know what forget I said anything about this being easy.
    Any comments, suggestions or input would be appreciated.
    Re: 1981 "SpaceCraft Boat Works, Miami FL" 23.33ft 4100lb V240 Super Sport
    It's called a Stringer drive.
    2002 20' Hydra-Sports 202DC 200HP Yamaha HPDI
    1976 18' Starcraft SuperSport 90HP Evinrude
    Restoration thread http://forums.iboats.com/showthread.php?t=357767
    • #3
      Thanks mate, post updated.
      • #4
        PICS:
        There is a new 305 chevy 5.0l OMC included in the deal which i'll be installing. As you can see, it's "new to you" but certainly not a new motor. It will probably need some work as well.
        2. Spaceworks Boat Works is a very well known company in florida, but hardly known of elsewhere since their closure in 1991 (along with a great many other boat companies at the time). I am very excited to be bringing one of these back to life.
        3. All fiberglass boats are EASY to clean / restore and bring new life back too.
        #1 explains #3
        A good brand of engine is one that runs
        • #5
          I've edited my post to better reflect my original intentions when writing the statement. It appears that the above poster mis-understood me.
          Hope thats cleared up.
          • #6
            Updated with new pics. Got a shop vac and went to town. Cleaned out the entire engine bay too, now just need to remove the old 305. Going to try and do that this weekend.
            • #7
              Wow www.sterndrive.info is such a great resource for this OMC stuff!!!
              I haven't been able to find one part though, the big accordion looking bellows that goes around the entire outdrive at the transom. This evidently is what allows everything to move as one. I want to replace mine before moving forward since its an obvious dry-rot prone part.
              • #8
                I've edited my post to better reflect my original intentions when writing the statement. It appears that the above poster mis-understood me, which resulted in his unnecessary and immature insult.
                Sorry, no offense intended, just that buffing and cleaning fiberglass can be very time consuming and hard work..
                • #9
                  Hey no prob man! And yeah it can be quite a bit of work, but not nearly as much work as stringer replacement and re-glassing. Now THAT makes me wanna throw the towel in!!!
                  I don't mind a little scrubbing, pressure washing and wet sanding / buffing. You don't pass out from fumes, or have time limits haha.
                  • #10
                    So this boat has no wood in it?
                    • #11
                      From what I can tell not a single piece other then the teak doors, occasional teak trim (to place fishing rods on on the sides) and teak swim platform and kicker for an emergency outboard.
                      I am going to remove the aftermarket seats that were installed next and open up the main bilge panel in the floor. I believe that is where the fuel tank is, i'll know more once I get in there I guess.
                      From what I understand on boats like this, they used a steel beam or something else for the main keel stringer, and fiberglassed around it.
                      • #12
                        Let me ask you guys something, if you open the filler cap for the fuel tank (which hasn't been opened in probably 6yrs) and a MASSIVE vaccum nearly keeps you from pulling it off, and when you do it sucks cavernous air in, is that a good sign?
                        I take it as a sign the fuel tank is still sealed / intact with no leaks! Also it had 0 smell (not even a fuel smell) which means it was probably drained. I'll know more when I get the panel up this weekend but just thought i'd ask.
                        • #13
                          Well the weekend is here, I plan on working on the boat the whole time. Going to remove the old seats, get the floor panel up and check out that fuel tank.
                          I am also picking up the new engine and bringing it back to look at. I just realized that i'm missing a lot of random cooling hoses, fuel line and what looks like every single bolt for the bellhousing.
                          Hopefully those things won't be very hard to procure and at low cost.
                          • #14
                            It shouldn't have a vacuum if it was properly vented. I'd definitely be checking for a blockage on the vent.
                            • #15
                              Yeah good point, i guess i'd rather have a stuck vent then a busted tank though (if the choice were mine to make) so i'm still on the winning side
                              Just picked up a Ford 302 that is freshly rebuilt. Not sure whether or not i'm going to put the 302 or the 305 chevy in there. It would appear I have the bellhousing type deal for both so I can mate either one up to the stringer.
                              The OMC chevy in my pictures was pulled from a boat, no idea what shape it's in. This ford is brand new, so i'll probably go with it.
