sphelps
- Nov 16, 2011
- 11,432
Small update .. All the electrical is done other than installing the 2 deck lights on the side panels and hooking up motor and controls . Stick steering almost complete .. Discovered the shift cables need replacing . They work but are cracked and corroded.. We decided to go ahead and mount them so the mechanic could go through the motor then replace them after we are sure everything else checks out . From what Lisa tells me the motor runs fine but the lower end has issues ..
May go ahead and hook the muffs up and see if it will come to life . Whats the oil to gas ratio for a 74 Johnson ?
Also moved the boat up further on the trailer ,Moved wench post and I made new 2x6 bunks that run all the way to the transom . Much better now .
Prolly could use a set of guide post to help the girls with retrieval..
Hope everyone is having a great week ! :joyous:
