Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Alumium Boat Seat Replacement~What type of wood?
  • Alumium Boat Seat Replacement~What type of wood?
    I have a very old aluminum boat that I want to replace the seats in. 2 have been replaced at one time and need done again. The boat is strictly a lake boat and will most likely never hit any speed as where I intend to use it does not allow gas motors at all so I will be limited to and electric trolling motor.
    The brackets that the wood sits in are about 1" in spacing so that limits the size of the wood that can fit into them. The boat is a typcial 58" wide
    I am far from a wood expert but I have worked with it some. What type of wood should I use for strength? I am 240#.
    Do I gain anything by putting reinforcement under the seat in perhaps a box design of some sort either out of wood or metal?
    Fishing for 65 years.
    Retired and liking it a whole lot better than work!
    Lowe 1467WT with Mercury 20 HP 4 Stroke and Min Kota troller
    Re: Alumium Boat Seat Replacement~What type of wood?
    Yellow pine is strong and durable but nominal standard thickness is typically 3/4 inch or 1-1/2. Another suggestion that may work is using 5/4 pressure treated decking boards. They're strong with a bull nosed edge and depending on the width of your seat you'll need more than one. Typically they are 5-1/2" wide and 1-1/8" thick which may require a little sanding to get them to fit the supports. Yes, you could add support in the center by making a box-like configuration below the seat and just attaching it to the seat......not the boat bottom, obviously.
    If you can't fix it with a hammer it's an electrical problem
    • #3
      Thanks for the ideas. I have never heard of yellow pine out here.
      I am going to have to hit the lumber yard I guess.
      The reason I asked here is that most corporate lumber yards today seem to hire kids that know little about what they sell.
      • #4
        Ayuh,... I'd just use 3/4" plywood, 'n shim the mounting ends, if needed...
        • #5
          Does that need to be marine grade or just normal plywood?
          • #6
            Hello keninaz...
            What kind of visual finish are you wanting ?
            IS $ an issue ?
            You say the wood fits in slats of the hull ? Am I understanding this right ? ( basically multiple strips of wood make up the seat ? ).
            Got pics ?
            I know Im asking alot of questions..but I dont want to give the wrong advice here...
            YD.
            Do your best and caulk the rest
            • #7
              You don't want pressure treaded wood touching aluminum. It will corrode the aluminum.
              Dave P.
              1979 22' Starcraft Supersport V5
              w/ 1985 Evinrude 140
              My original thread about my boat:
              http://forums.iboats.com/showthread.php?t=416445
              My restoration thread:
              http://forums.iboats.com/showthread.php?t=427003
              1995 FourWinns Freedom 3.0 I/O.
              1995 14' SeaFarer LW
              Sold....http://forums.iboats.com/showthread.php?t=543525
              • #8
                Originally posted by Yacht Dr. View Post
                Hello keninaz...
                IS $ an issue ?
                Got pics ?
                YD.
                Finish is not important. I will most likely cover it with something to make it easier to sit on for extended periods.
                Who knows what the original seats were like, and the floatation that was under 2 of the 3 is long gone.
                I am posting a pix of the bracket where the front seat was removed before I got it.
                • #9
                  Ayuh,... Normal plywood, painted, yes...
                  CDX is probably abit rough for a visable seat,.....
                  ACX would work quite nicely though....
                  • #10
                    Does it matter if it's going to have a cover on it?
                    • #11
                      Nope,...
                      You could drop back to CDX, if the money is the issue,...
                      It's purely a Cosmetic thing...
                      • #12
                        I would go Mohogany if it suits your pocket book..
                        Your going to have to account for resin coatings and such for regular ply..or even MG ply..
                        If your going to permanantly cover your wood.. thats another story..
                        IMO your hardwoods will last longer and have a wider "use range" out of the seats..uncovered that is..
                        YD.
                        • #13
                          Cut two pieces of 1/2" CDX and laminate them together. Seal them with varnish or sanding sealer. Screw a 2x4 vertically across the bottom for extra ridgidity.
                          Cover the top with Nautilex or Maritex non-skid vinyl (like many of the upscale utility boats.)
                          2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
                          2015 Yamaha FX Cruiser HO
                          1984 Stingray SVB190SS & Mercruiser 3.0 Liter 140 & Evinrude 9.9 Kicker
                          1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
                          1960 Mulray 100 Dinghy, equipped with Beaver Oars
                          1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
                          68 Outboards: 1919-2017, representing 11 manufacturers
                          Member ACBS, LBOA, AOMCI
                          • #14
                            That sounds like it would be strong and reasonable too. Might just be a good plan. Thanks.
                            • #15
                              Aye..yes..but my way has the seats for multiple applications..
                              Cover the seats..there for you butt..
                              Nonskid your seats..hard on a knife...
                              Im suggesting seats that you can get blood on..and wash/rinse..fish..
                              Now if you want permanant comfy seats.. I can arrange a post on that...I was thinking Fishing......
                              Oh..and you might want to step on the seats when that bass goes to the other side of the boat .. Safty..
                              Bare wood is the safest/cleanest and most effective way you can rig your fishing boat IMO...
                              Decide on what you want from Your fishing aspect and go from there..
                              If seats are only that..then yes make them out of whatever.. ( Ill tell ya that after buying all this sealant and resin and grip tape or other paint to coat your ply your going to spend as much as you would have with good Top of the line Timber that would basically last forever LOL ). Been there done that..
                              YD.
