Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
Fiberglass work in cold weather
  • Fiberglass work in cold weather
    I need to start the glass work on my stringers and deck on my 21' Four Winns but temps are in the 30's in NJ.
    The boat is tented in with tarps,my question can it be done? Can I pump in heat from a propane heater to aid the curing process,or should I use some electric heaters? Just looking for some ideas! Thanks!
    87 Four Winns 210 Horizon 350 Merc/Alpha 1
    Resto Thread 210 Horizon http://forums.iboats.com/showthread.php?t=458229
    Re: Fiberglass work in cold weather
    We had a member here that heated his transom work space to do cold weather fiberglass work. I do know there are specific temperature ranges for fiberglass. Being tented and heated is nice however...... The fumes will be overwhelming.
    I hope who ever did the cold weather work will pipe in...... I don't remember who it was
    This is a great link to boat specifications http://boatspecs.iboats.com/
    Please, shop iboats first!!
    • #3
      I did find this http://forums.iboats.com/showthread....s+cold+weather
      • #4
        Thanks Bob I did see a limited amount of info when I searched... I'm a little hesitant in using the heater with an open flame because of the flammable nature of resin fumes....I guess heat lamps would be my best bet... I can open parts of the tent to allow ventilation when working and then seal it up and keep it warm inside. Maybe someone has done this before and can give me some insight
        • #5
          Ayuh,... 1 trick is to have whatever you're puttin' resin, 'n glass On, up to temp...
          A COLD hull will suck away any heat you put into a small area you're workin' on....
          Ain't sayin' Cold weather glassin' Can't be done, but it is Troublesome...
          • #6
            Hello Rick..
            The first thing your going to need is a Resporator !..
            If you can bring the temp up to about 70ish and the surface isnt cold then your golden ( with a respo ).
            I wouldnt keep your tent open when your glassing ( the glassing shouldnt take too long on a 21 footer ).
            You can use your propane turbo heater to get the warming process up and turn it off before you start the layups. ( keep a fire extinguisher on hand ).
            Basically your working in a climate modified CAVE..you warm it up..get in do your biz and get out. You should have someone to check on you every so often.
            YD.
            Do your best and caulk the rest
            • #7
              Thanks Doc
              I do have a good respirator and will be working with a buddy. I will heat everything up to temp and do my lay up.... then I'll close her up and have some electric heaters to keep the temp up while it cures.
              This site is the best! It's refreshing to find nice people willing to lend some knowledge! Thanks again for everyone's input!
              Happy Holidays to all!
              • #8
                i know for a fact ive tried it you cant fiber glass 50 deggre or less weather. and thats a bad idea to do with heathers in a plastic tarp thing. the fumes if get to much could elode the tent your in your better off waiting to spring or puting it in a gararge with ventilation. i plan on fiber glassing my new deck in spring and be on the water in a mounth or so after
                • #9
                  Nothing will Explode...
                  Heat your tent..then glass....
                  Your house will stink .. way bad..but it wont explode .. you have more chance of spotanious cumbustion with wheat or flour then you have with resins...
                  Gasoline on the other hand....bad bad in your garage...resin..not so bad...parts per/sq ft is Very low to explode when your even using a power grinder...
                  Ive Never seen glassing explode..or even catch fire in a hot bucket..but just me...
                  YD.
                  • #10
                    i did a thread on this a few years back, no problem !
                    cant find the thread......but its called glassing in cold temps.....i think its also in the hull extension thread.
                    what you have to do is fool the materials !
                    keep your resin and glass in the house. (so they are both at the 75 deg range)
                    heat the substraight with a big quartz lamp.
                    heat the air as best you can.
                    mix everything
                    run out with the materials and glass it.
                    keep the lamp on it and the heat in the air as long as you can.....done.
                    resin and glass wont know its cold if you have the substraight warm/hot. the substraight will keep the mix warm till the reaction starts.....
                    the trick is to keep the lamp on it while the resin is coming off the back end of the cure....this will give you the stregnth.
                    your repair can be done just as strong as you doing it in the summer.
                    cheers
                    oops
                    The Hull Extension Thread
                    great info on all aspects on boat building with detailed information.
                    http://forums.iboats.com/showthread.php?t=234392
                    IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
                    IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
                    November 29 2010 RIP
                    • #11
                      Thanks Oops
                      • #12
                        You also might consider Infrared lamps for heating the substrate ( the hull ) ..
                        They are 250w ( HO heat bulbs/low light ) instead of the 500w Halogens ( HO light/lower heat + more $$ to run VS. IR bulbs ).
                        Basically your home Depot hollowgens ( pun ) is good for light..but not so good for Heat ( especially directional heat ). And 500w a pop it kinda like buying a heating pad to boil water..Very expensive to use.
                        Red ... think Red when heating something .. there are other High end IR or radiant products..but for 10 bucks a pop for IR bulbs@250w..they are hard to beat ( oh..and they dont blind the crap outa ya.. they just make your light blue walls look funny when you get out of that environment lol ).
                        Peace.. YD.
                        • #13
                          I don't do it period, there are many more variables that come into play, especially with the method you are thinking of using.
                          The chances are greatly increased for voids, air pockets, poor adhesion, etc.
                          The biggest problem is maintaining a consitent temp on the surfaes you are working with, and if nice gust of wind comes up and blows a tarp open you better move quick to attempt to keep those temps where they were.
                          If you really must do it, then use heat lamps and stay away from propane and kerosene heaters. Even then I strongly recommend pulling the cars out of the garage and let them reside temporarily in the driveway.
                          1985 Baretta Vanguard 16ft & 1984 Evinrude 75hp O/B
                          ****Running your motor without water is like peeing into the wind, it's a stupid impulse that is going to be a mess later****
                          • #14
                            Halogens throw out a lot of heat, they illuminate ok too.
                            I did transom work in cold weather.
                            sigpic
                            See FAQ Files.
                            http://forums.iboats.com/showthread.php?t=299680
                            Get the genuine factory service manual.
                            www.outboardbooks.com
                            • #15
                              Just want to chime in here and say it can be done... I've been working on glassing my stringers/deck and it's been less than 60* every day (40s some days!). Only one day did I have any curing problems and that was because my heat died out early so it got cold (and incorrect mixing ratios)... brought the heat back up the next morning and the stuff cured.
                              I can't say for using any kind of gas heat, but I can say that I had no problems using an open flame because I was using a wood burning fireplace. My "boat tent" is about 20ft x 15ft so it's not real big. The fumes didn't get too bad but my tarps aren't air tight so some air was gusting in with the winds.
                              It would be a good idea to get a cheapo thermometer that you can hang by the boat to monitor temps..
                              One more thing.. Good idea on storing the resin inside so it stays room temp, BUT be ready for it to stink up the whole house, even if the lids are on tight. I tried this one time and the next morning the smell about knocked me down! Needless to say, there were some other not-so-happy people in the house too! This was with 5gal buckets, can't say for the one gal jugs. Maybe putting them inside a garbage bag and sealing it would help with the fumes.
                              Good luck! I'm too impatient to wait for spring... boat needs to be done by then (hah!)
                              1979 StarCraft Viking Elite 190 Deck Boat
                              Mercruiser 470 / One Drive
