I got this boat a little over 3 years ago, everything was rotted. Being a new boater, I simply through a new floor in it, and went fishing...I am a Tournament Fisherman, and the wear in tear this boat has sustained needs some attention. Since I cant afford a new one, and the facat that this boat means so much to me, I started a rebuild. And I love a project!
Last year I noticed that the aluminum brace that goes along the top of the transom was pulling away from the rest of the transom very bad. As a temporary fix, we cut out the bad section, and replaced it with some metal that we put over a break, and folded several times, this fixed the problem for a while. It just looked hideous, I removed it now and the transom is just completley shot. Needed to be replaced back then, especially since I put a 150hp Yamaha in place of an Evinrude 112hp.
But before that, I had to address the water logged foam that inhabited the boat underneath the floor. Man this was a nightmare to get out, as many of you know..I dont think it was as bad as many of you had encountered. It was soaked about 2 inches threw from the bottom up, the further back I got, the worse it got. Here are some shots of the before and after.
