I believe I have waterlogged foam in the hull of my bass boat. Anyone have any suggestions on what to do or where to go from here? I noticed the boat was sitting a little lower in the water than it should, the motor when trimmed all the way down will not plane, but will plane when trimmed up a little higher. Any way to fix this and get the water out without spending a fortune? I think I have the leaks sealed, need a way to remove the water. I have the front of the boat propped up about 5 feet to try and drain any water i can out of the back, but at 1 drip of water every 15 seconds it will take a while! Thanks
