Re: Transom rot !!
welcome to i boats.
get your wood now.....i suggest at least one layer of one inch ext grade ply...make up the rest with what ever thickeness ply you need. the one inch ply is a really stable wood to work with....
you might get a one inch and a three quarters, and the rest of the thickness will be glass.
engine and out drive removal...= 4 hrs
transom removal = 6 hrs avg (it varies)
hull prep = 2 hrs
clean up = 1 hr
transom build = 3 hrs avg
instllation = 1 hr
cure of instlation = overnight
glassing and cure = 3 hrs
tie ins = 6 hrs avg
cutting the hole and glassing = 2 hrs
gellcoating bilge and new transom = 1 hr
paint bell/ drive /housing = 1.5 hrs.
re instllation of housing = 1.5 hrs
motor installation = 3 hrs (includes hook ups)
these are professional times.....and all times vary
for a first timer.......triple all numbers !
a first time dyi can do a transom in 40-70 hrs depending on skill level.
we just did a 32 footer with twins (bravos) in under 28 working hrs total.
the only time the work slows down is when you dont know what to do next or how to do it.
we are here to give you all the help you need or want....post if your stuck and we can assist quick.
cheers....and good luck.
oops
