Hi guys in the process of a restoring a 1979 18' Wilker boat. Right now the floor has been ripped up and stringers removed and also managed to grind down the old fibergass that was used to hold the flooring and stringers down.
Here is my plan of attack for next stages once I have the new stringers and flooring cut and ready for install. The flooring will be exterior grade 5/8" plywood, and cross members will be pressure treated 2x4 and stringers will be 5/8' exterior grade plywood cut to same dimensions as orginal.
1.) Cover the flooring, stringers, and cross members with finishing polyester resin that has been thinned with acetone to allow it to really soak into the wood.
2.) While the 1st coat is still tacky apply a second layer of finishing polyester resin.
3). Maybe apply a 3rd coat (not sure if really needed).
4.) Use an epoxy resisn and 3-6" fiberglass tape to attach the stringers and cross members to hull and join all together by covering each seam and bulkhead.
5.) Use an epoxy resisn and 3-6" fiberglass tape to secure the flooring to sides of hull.
6.)Use epxoy resisn and fiberglass top side of flooring with 1.5 oz. fiberglass mat (1-2 layers).
OR
5.) Use fiberglass resisn instead of epoxy.
6.) Use fiberglass resisn and fiberglass mat.
Trying to save a bit of cost by going this route and also I understand that epxoy is a true adhesive so hoping I can save a bit on the bottom hull prep work (grinding and more grinding) of attaching stringers to hull.
I would like to use polyester resin (cheap) and f/g for the top side of the flooring but understand I will really need to grind down and prep the sides of the hull and grind down the old layer of fiberglass used to hold the floor down.
What are everyones thoughts?
OR
