Speakrdude
Ensign
- Feb 25, 2004
- 942
Hello All. I need some advise. The most recent project I am working on is an 88 Sea RAY 300 Sundancer.
This boat will be used by myself in fresh water so I need a holding tank and a means to put out.
It has a SanX system currently, but does not have a pump out and only the small treatment tank system. It has the Vacuflush system, with a large diaphram pump coming from Vacuflush output to the treatment tank input, and then another large diaphram pump coming from the treatment tank output right out the side of the boat.
My question is, Due to space constraints, Should I pull the treatment tank completely and replace with a simple holding tank. Plumb it to a deck pump out and call er done?
