18Starcraft
- Sep 20, 2009
- 46
while replacing worn rivets in my hull I came across a hole larger than the 3/16 rivets would fill. What is the best way to fill this hole? Is there an epoxy or J&B strong enuf to fill the hole or should I rivit a patch in place? The boat will be in the water for the season & I'd rather do it the right way. I cannont get to the top of the hold so whatever I do will have to be done from the bottom only. Thanks to all you smart guys out there
