Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Easy Stick Steering, home made
  • Easy Stick Steering, home made
    Easy Stick Steering.
    OK, I had this 1950ís 14 ft Starcraft, and a 25 hp Evinrude electric start. What was I going to do with it?
    Using it alone with tiller, all it would do was stand on the
    Transom. Needs forward controls. Ezy glide stick steering is almost $400.
    Well I decide, to join new and old technology.
    Cable Pulley Steering, and Stick Steering. I am not the first to do this, as I have seen, small crab boats with it.
    It can be done in the center, as I have done. Or on the side.
    You start with an aluminum, mounting/swivel plate attached to the hull. Then thru bolt you stick to the mount. It should move freely. Now you have to build a guide for the stick. Just aluminum stock, with a spacer on each end.
    You will need 6 pulleys, and mounts. Only 4 of these http://www.iboats.com/Steering-Cable...-view_id.38768
    Cable, (Lowes) and the 2 smaller pulleys for the motor connection
    You also need 2 eyebolts, one on motor, one on stick.
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    Re: Easy Stick Steering, home made
    more pics.
    FLORIDA GATORS
    TEBOW Country
    • #3
      two thumbs up !
      The Hull Extension Thread
      great info on all aspects on boat building with detailed information.
      http://forums.iboats.com/showthread.php?t=234392
      IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
      IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
      November 29 2010 RIP
      • #4
        Cool, be great for maneuvering in the shallow's.
        Cheers...Kenny
        sigpic
        My recent projects...
        1961 Starcraft 18' Holiday - Sold
        http://forums.iboats.com/showthread.php?t=364883
        1979 Imperial 17' runabout - Sold
        http://forums.iboats.com/showthread.php?t=324091
        • #5
          yes it is, you can stand there and see the fish beds.
          FLORIDA GATORS
          TEBOW Country
          • #6
            awesome!
            you must take a video of this in action. it just looks too neat. I would personally add a handle bar
            now i am just waiting for the thread when someone takes the idea of the total gym and applies it to a remote steering setup
            • #7
              I like it! Might even try it on my little fiberglass. Thanks for the Idea.
              • #8
                Great,simple and effective.Stick could be along the side with a forward /backward movement.
                The cables could be run down one side if one side had rod storage or something in the way.
                I had two stick steer boats from the 1940s .All done with 1/2" galvanized iron pipe but for a wood stick.
                Just a simple lever on the rudder in the stern.
                For 60 or 70 years just about all the inboard boats with steering wheels used iron pipe between the steering wheel and the rudder.
                they had wooden blocks to help support and guide the pipe,usually a simple wood block near the steering box to limit travel.
                Back to Top
