Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Drain Plug - Inside or Out?
  • Drain Plug - Inside or Out?
    Okay, this may be a dumb question or one that has been answered many times in the past....but is it okay for me to put the drain plug in from the outside of the boat? I have had three other boats in the past, and it was easy to put the plug in from the inside, but this Holiday that I have now is real tough. I have run the boat with the plug on the outside twice last summer, but I always have this fear in the back of my mind that the plug is gonna come out. I do keep a spare on board, but would rather not have to use it!
    Jerry
    12' 1969 Monark
    http://forums.iboats.com/boat-restor...de-636668.html
    25' Sea Ox 250c
    http://forums.iboats.com/boat-restor...sh-589786.html
    Re: Drain Plug - Inside or Out?
    Plug on the outside is very common. Probably more so especially when size creeps up and you simply can't reach it.
    Torque gets you there. Horsepower gets you there in time for dinner.
    • #3
      I just go with whichever is easier.
      • #4
        If your plug uses the flip down lever, make sure that the lever isn't pointed down and in the path of the water.
        I have seen one get released by a stick (or something) that a customer's boat passed over. I prefer the plugs that use the T-handle that turn to tighten!
        Happy boating!
        • #5
          My boat has a 2" drain plug and I put it on the inside, so if for any reason I taken on some water, like a heavy rain, and the bilge pump didn't work, then I can remove the plug from the inside while running at about 20MPH down the river and it will suck all that water out of the boat. This works well if you have some stinking water in your bilge, say from fish guts, dead rat, dead frogs, etc. And of course, the inside plug can't fall out and get lost. Good Luck!
          • #6
            it really depends on your set up. if you can get to it easily from inside, then do so. both ways are correct. i prefer the T twist type plugs.
            FLORIDA GATORS
            TEBOW Country
            Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
            That is what these forums are for. Post your questions, in the appropriate Forum.
            • #7
              i use t type out side but as stated if you ever start flooding just get on plane and water will go out. aoutomatic sump is a plus as it will let you know before it is two late.
              1973 Starcraft Supersport
              120 mercruiser 153c.i.
              • #8
                I DEFF AGREE.. get the auto float switch for sure and the t plug.. the t plug seems to fit a lot better than the flip handle one....
                But get the float.. if you forget to put the plug in (common) you will know as soon as the boats in.. i did this once and i parked the truck and walked down and saw that the bilge pump was already running.. i knew exactly wat it was.. i cant get to it from the inside so i had to run back up and put the oat back on and throw the plug in..
                1986 Larson Senza V-175BR
                1977 Columbian Celebrity 14'
                New England Get Together.. Still getting ideas!! Come join in the fun!!
                http://forums.iboats.com/showthread....67&pagenumber=
                IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
                November 29 2010 RIP
                • #9
                  ive been wondering that too ever since i bought my boat. ive never had problems with it falling out and its just a lot easier to put in on the outside being the motor is in the way.
                  1981 Wilker Galaxy 18' 120 hp omc with stringer outdrive
                  2005 Dodge Ram 1500
                  • #10
                    Okay, thanks all, I feel better! I currently have a flip handle plug, but will change to a twist plug. I do have a pump with an automatic float switch.
                    Jerry
                    12' 1969 Monark
                    25' Sea Ox 250c
                    • #11
                      I run a t-handle on the outside and have a spare on a short piece of small chain laying in the bilge. If something happens and I loose the one on the outside I don't have to go swimming to avoid sinking. I also keep a spare in the emergency kit.
                      • #12
                        I'm installing mine (on a 22 footer) with the screw in brass plug on the outside and a rubber lever type on the inside of the tube that's kept nearby. If I need to plug the tube with it I can do it quickly, and then decide whether to pump out the water and go boating or pull the boat and put the brass plug back in.
                        I won't use the rubber or lever types on the outside since I have divers coming aboard there... using the plug as a foothold risks pulling it out and ripping up dive gear...
                        Erik
                        Sea Ray SRV-210 - Winter refit
                        75-85 foot displacement hull trawler - gleam in my eye
                        • #13
                          So I have ALWAYS put the drain plug on the outside of the boat... But the boat we just bought has the plug tethered inconveniently to the inside. It's the latch style plug. 14 foot with 30 horse outboard. Any reason at all I can't start putting plug in from outside?
