Re: suzuki dt65 1990 on to an 18ft boat previously with an inboard
It sounds like you're talking about an I/O, by the way, not an inboard (an inboard would have the prop under the hull, not on the back).
was just wondering what the main difference in the back of the boats was? obviously a boat made for an outboard would be stronger but what would make it stronger?
What makes it stronger is the fact that the transom is thicker, more heavily reinforced and bonded to the hull, and usually knees (triangular braces) attach the transom to the stringers. You can reinforce your transom some, but unless you either replace it with something thicker or layer another thickness of fiberglass and wood on top of it and then add the bracing you're talking about, it won't be strong enough. Hence my comments about rebuilding the transom.
and with the boat designed for the in board im sure there must be some strength back there, im gonna spread the load pretty much across the back of the boat, the worst case is if i put it in reverse the engine may pull the back of the boat off but im sure it cant be that weak....
Actually it can. Depending on the condition of the existing transom (if it's rotted at all) the first time you reverse (or for that matter throttle up in forward) the engine can twist off its mounts and fall in the water. It's happened to people with bad transoms.
An inboard transom is weaker than an I/O transom which is weaker than an outboard transom. The I/O transom has the sterndrive running through it and bolted to it which takes some force, but doesn't hold up the weight of the engine. The outboard transom absorbs all the force of engine thrust, holds the engine block in the air no matter how the boat tips/tilts/stops, and also transmits all that force to the rest of the boat.
I know you're looking for someone that's done this sort of job, and there are a few people around here who have tried it or done it. But some of the most expert folks on this board have replied to you.. they've seen this done in their shops or by friends, and are giving you their best advice. If you're determined to do it, we'll help and comment (post pics). Maybe if it works for you and you do a great job you'll change some minds. Or, maybe not.
It CAN be done... cheaply or safely, pick one. I encourage you to not sacrifice safety. I know it just doesn't "sound right" when people say you can't do this and have it work well, but intuition can lead you astray sometimes.
Erik
