SKIBUM1M
- Jul 17, 2009
- 604
I plan on ordering gelcoat on wednesday to recoat my boat. The reason I plan to gelcoat instead of paint is I plan to change the color from white and tan to yellow and purple. If I paint it I am afraid that any small scratch will go thru to the white. It is a bowrider so walking on the paint will cause it to wear thru pretty quickly as well as on the swim platforms. Paint is only about 3 mils thick where gelcoat is about 20mils. this also alows alot more sanding and buffing in the future.
Alot of people here advise against gelcoating. I have experience spraying automotive paint and I wet sanded and buffed out all the orangepeel on my thunderbird so from what I have read gelcoat shouldnt be much different. I plan on alot of time sanding and buffing after the gelcoat is sprayed. Am I missing anything major? Am I making the wrong choice in gelcoating and if so why?
I have had someone suggest using duratec high gloss additive. Has anyone used it? what are the advantages of it? Does it make that much of a difference? since you mix it 1:1 do it go the same as 2 gallons of gelcoat would if I use 1 gal of gelcoat and 1 gallon of duratec?
Thank you for any advice in advance.
