Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Filling the gap between plywood floor??
  • Filling the gap between plywood floor??
    Ok guys, What is the best way to fill the gap between the plywood floor pieces I will be putting in soon?? I think Systems West has a crack filler?? What about gluvit as I just was reading this?? Any other ideas??
    Gluvit Epoxy Water Sealer brushes away leaks, seeks out and fills and seals leaks throughout boats and homes. Gluvit is a paintable waterproof epoxy sealer that seeks, fills, and seals cracks in wood, fiberglass, and metal.
    Re: Filling the gap between plywood floor??
    I cut my floor so I just put cloth strips over the seems and glassed in the whole deck. If you have larger cracks I would use peanut butter or long strand fiberglass filler.
    sigpic
    Buy American
    1993 Ford Thunderbird rebuild
    http://www.cardomain.com/ride/3351730
    1990 Larson All American 150
    http://forums.iboats.com/showthread.php?t=358025
    If its worth doing, it's worth doing right
    • #3
      I used a little bit of Epoxy with 'cabosil' filler added to it- The seams weren't that wide, so it probably didn't NEED it- But I did it anyway!
      All my seams ended up on frames, so they had backing under them. Of course, it's all glassed over, too...
      -Andrew
      Back to Top
