Hey guys. Im trying to spruce up my used Wellcraft. I have taken the engine cover off and removed the vinyl and foam from the plywood. There is lots of rotten ply there, so I am going to build a new cover and reuse the foam and vinyl as they are are in pretty good shape. I hated to watch the vinyl flapping in the wind when trailering or at speed on the water. Is it proper to glue the vinyl to the foam in this case? If so, what kind of adhesive should I use and is there a technique to get the vinyl in the right spot?
