Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Cuddy wall covering questions....
  • Cuddy wall covering questions....
    Hello, I'm trying to figure out if the white ish carpet like material on the cuddy walls is what was between the hull and original carpet/cuddy wall coverings. Also, the stains in the white material in some pics looks like rust around starboard window and on port side window almost looks like a resin stain. That's why I think the original wall coverings are missing. Any thoughts, suggestions, words of wisdom is greatly apprecitated.
    http://s939.photobucket.com/albums/ad237/noizmaker2pb/
    http://forums.iboats.com/showthread.php?t=362228
    1988 Nordic Crestliner Crusader 245
    Re: Cuddy wall covering questions....
    Hey there, I to need to figure this out, what to cover the cuddy cabin walls with. I've been noodling this around for a couple of weeks, and haven't come up with much of anything good, just a couple of ideas or well 1 idea.
    i was thinking about making some vinyl panels to inset in the cuddy.
    step 1. Template for plywood
    Step 2. Cut Plywood
    step 3. Attach foam
    step 4. Cover with Vinyl
    step 5. Attach to interior. (which i haven't figured that out yet either)
    I think it would be comfy and great for the kids to bounce around in, stylish, and would be totally custom. Not sure of the effort though.
    The carpet in mine is super dingy and needs to be replaced, and i'm not hip on replacing with more carpet.
    Open to ideas
    T
    There is much to be said, in a world like ours, for taking the world as you find it and fishing with a worm.-Bliss Perry, 1904
    Project
    1974 Starcraft Chieftain
    http://forums.iboats.com/showthread....errerid=174999
    "Completed" Project
    1991 Starcraft Islander 191V - Rebuild
    http://forums.iboats.com/showthread.php?t=359551
    • #3
      Well regardless of what you install...carpet or vinyl the biggest problems in a cuddy is lack of drying out. They always tend to smell like damp mold.....
      I think your vinyl idea sounds great. The 1" foam is fairly cheap and the vinyl will clean up real easy too.
      This is a great link to boat specifications http://boatspecs.iboats.com/
      Please, shop iboats first!!
      • #4
        Step 2. Cut Plywood
        step 3. Attach foam
        Open to ideas
        T
        did you copy that idea from me?
        I figured some luon or whatever it's called would work fine to attack the foam and vinyl too. I got thinking that you could put like a carriage bolt through a little scrap piece of wood, epoxy it to the wall of the cabin, then use a nut and washer with a screw head cover. A few of these should be enough to properly hold it in place. Add 12V limo style rope lighting at the seams
        197133' Chris Craft Coho/Catalina Sedan, twin CC 327QA's, Paragon V drives. Restoration in progress1985 Bayliner Capri 1952 (19' cuddy),OMC 3.0L. Restored with the knowledge here on iBoats'70 (circa) Amphicat 6x6 AATV, future Coho tender'87 Kawasaki 650SX, '90
        Tow rig: '74 Buick LeSabre Luxus convertible 455ci cude U 4BBL factory dual exhaust
        • #5
          If you are talking about a covering to finish the inside fiberglass surfaces of the hull (not covered with anything else) search the term "hull liner material. I found it once looking around. The inside of the cabin of my boat has it on the inside surface glued in place. Sort of like thick wall paper only nicer. You can get it as a thin carpet as well.
          I considered making some interior panels also. But you would be surprised how adding a little thickness to the walls will make the cabin look and feel smaller.
          "Your results may vary"
          Thundercraft in Progress
          http://forums.iboats.com/showthread.php?t=287390
          Tri-hull Wiring
          http://forums.iboats.com/showthread.php?t=448376
          • #6
            For our cuddy walls theres got to be material that can be installed and removed easily for end of season cleaning or storage. Similiar to the removable carpet flooring concept. Velcro and duct tape....
            Image of current cuddy wall material I'd like to replace.
            • #7
              that is a great idea, of epoxy studs to the wall. I think you just answered my last hurdle there. That is going to be my spring project, in the meantime i still getting out water logged foam!!
              T
              Project
              "Completed" Project
              • #8
                I didn't find anything on Iboats site, but did find this website: http://www.sailrite.com/HullBlanket-...ilver-Grey-M66
                This may be a much easier option.
                T
                Project
                "Completed" Project
                Back to Top
