Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Rub Rail end cap aluminum casting
  • Rub Rail end cap aluminum casting
    Where can I get a replacement aluminum casting? This part overlaps the two rubrails that come together at the bow. The boat is a 1976 AMF Crestliner 995 Crusader. Any help is appreciated.
    1976 AMF Crestliner 995 'Liberty'
    190 OMC I/O
    Easy Loader Trailer
    All restored 2009/2010
    Re: Rub Rail end cap aluminum casting
    It's probably cast zinc. West Marine or other boat store will have it.
    • #3
      What is the size? Length, width, etc. I replaced my old rub rail when I rebuilt my boat. I may have it laying around.
      As in people, there comes a time in your life when you realize what boat will always matter, what boat does matter, & what boat never did. So don't worry about the boats from your past, there's a reason why they didn't make it to your future. .
      1978 MFG Gypsy Rebuild Thread
      1978 MFG Gypsy Rebuild Video
      First Launch After Rebuild
      1979 Sunray SW149 Bow Rider Rebuild Video
      1976 Sunray Boat Floating At The Wharf
      • #4
        Thank you for your replies. EsoxRanger - I was not aware of West Marine as a supplier. I visited their site and did not find a casting that would meet my need. TallCanadian - the piece overlaps the rub rail on both ends so it makes a radius of approximately 90 degrees at the bow. It's 1 1/4" wide, 1" deep, and about 12 1/2" long if you measure from one end along the front around the radius to the other end. I'm new to this forum so I'm not sure if it's okay to include an image. Maybe a small thumbnail?
        I'm just getting started on this restoration. This will be my 4th project.
        TallCanadian - nice job on your boat restoration!
        190 OMC I/O
        Easy Loader Trailer
        • #5
          Thanks mrlassi. A picture would be great if you could.
          • #6
            Here are a couple of views. The broken casting (110 degrees) is the short one pictured here. The other is from one of the rear corners (90 degrees). You can also see how it overlaps the rub rails on each side of the bow. Any idea where I can get a replacement?
            190 OMC I/O
            Easy Loader Trailer
            • #7
              My rub rail was bent at the turns on the boat. The only caps I had on mine were end caps, but they are not the size of what you have.
              • #8
                Looks custom, best to check the boat forums for your boat make. Junk yards, maybe fabricate one or fix that one? My Glastron site has many places to pick up parts. Sometimes dealers even can get them.
                Boston Whaler 15 SS Ltd
                Glastron GT-150 '79 Resto
                Hobie 18
                Hobie 17
                Glastron Jetflite Resto
                • #9
                  I bought a dock corner molding (vinyl rubber) and screwed/glued it to my bow. I would seal that seam first.
                  sigpic
                  See FAQ Files.
                  http://forums.iboats.com/showthread.php?t=299680
                  Get the genuine factory service manual.
                  www.outboardbooks.com
                  www.*****************
                  • #10
                    Would anyone know where/who would have made these castings for AMF? I also restored a Kenner Ski Barge that used similar castings to overlap the rub rails at the bow and transom corners.
                    There must be an OEM out there somewhere. My web search turned up zip.
                    Thank you for your help.
                    190 OMC I/O
                    Easy Loader Trailer
                    • #11
                      You might try rubrails.com They have about every rub rail you could think of, they might have the castings too.
                      Miss Morgan,1969 Sleekcraft "Boats by Nescher" Newport. Power by Mercury 115 L6, tower of power.
                      http://forums.iboats.com/showthread.php?t=364284
                      Current project,http://forums.iboats.com/forum/boat-...project-fuggly
                      "Nothing is done so poorly that the government can’t do it worse!"
                      “It’s easy being a humorist when you’ve got the whole government working for you.”—Will Rogers
                      • #12
                        Try the OEM dealer for parts.
                        This is a great link to boat specifications http://boatspecs.iboats.com/
                        Please, shop iboats first!!
                        • #13
                          Mrlassi1,
                          could I suggest that this would be easier to make than find?
                          All this shape consists of, using your photos as reference, is a pair of barely inclined plate arcs and some barely formed convex facing. This could be welded and routered to make a near exact copy from alloys that will last lots longer than castings.
                          I think you could make all that was needed by buying some 5086 0.187" or 0.25" thick plate, band sawing the top and bottom arcs using the pieces you have as patterns. Next, buy a 6063 pipe bend of 90-110 degrees, I don't know the arc, in the pipe size that has the same OD as the vertical front piece.
                          By cutting the front half of the pipe bend in the same wood working band saw that cut the two arcs of plate, and that would be easiest with a 6- 8 tooth per inch blade lubricated with Pam [the fried food pan spray], you could pretty easily cut your three parts needed to weld this hollow curved channel.
                          Any aluminum TIG welder can join the three parts and you can run it through a standard carbide round-over bit on a table or with a platten, again lubricating with pan spray. By rounding the weld with a bearing guided router bit, it becomes machined to a very smooth edge.
                          Finish by using three color variants increasingly finer grits of the 3M buffing pads, like Scotchbrite only hook and loop for a 4" grinder, and follow up with a metal polishing pad and you'd have the part better than new.
                          I've made plenty of welded versions of this vaguely similar types of hardware and the replacement is much more durable than the original, but then it's probably 50 times the cost as well.
                          Cheers,
                          Kevin Morin
                          • #14
                            Good News! I found a casting on ebay. It came from a vintage Chris Craft, but will work just fine. See image below. It had to be cut on the top inside edge to match the bow profile and now fits well. I appreciate the input provided by my fellow iboaters.
                            190 OMC I/O
                            Easy Loader Trailer
                            • #15
                              Great find!!!!
