Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
How to patch a hole in your boat hull (video tutorial)
  • How to patch a hole in your boat hull (video tutorial)
    It was bound to happen, you pissed off the wrong guy and he took a shotgun to your hull. Now you have to fix it in order to exact revenge on him and his. Here's how to get you back on the water for the next six gun shootout: http://www.youtube.com/watch?v=PzOMl...eature=channel
    The video skips the part about how to fill the voids left behind as well as fairing it. I used a mixture Poly resin, Cabosil and 3M glass bubbles and applied it using a plastic spreader. The cabosil is important, as it prevent sagging and dripping of the filler as you apply it. I then took 100 grit sand paper to sand it smooth to the hull and painted it. For big holes, I recommend using a 'long block' sander, as it will ensure the sanding job creates a perfectly smooth transition from patch to existing hull.
    If you have any questions, let me know.
    Cheers!
    1990 Bayliner Capri 2050 BR - (My first runabout; Never seen her in water) ***Restore on hold***
    Restoration status: Painting hull Watch my progress
    Progress so far: Teardown - Transom - Stringers - Deck - Paint - Re-power - Interior Panels - Seating - Water Trial - Upholstery
    The 10 steps of restoration denial - Which step are you?
    Re: How to patch a hole in your boat hull (video tutorial)
    Bravo! You're an asset to this site!
    You're gonna need a cameraman... lol!
    Rot never sleeps.
    • #3
      Just a thought, but do you think you should repeat the process on the outside of the hull?
      Rot never sleeps.
      • #4
        I don't, simply because I couldn't if I wanted to. By the time you sand it flush to the existing hull, you would have sanded off anything you added from the outside. The inside patch is plenty, so long as you apply the glass correctly.
        • #5
          Nice tutorial and what you did will most likely last, but I personally would have done a 2-sided repair for that size hole. Actually I did a 2 sided repair on mine for an even smaller hole. You can do 2 sided and still have the repair flush with the original exterior of the hull if you do the taper from the outside rather than the inside. I made a cartoon in MS Paint to show how (attached). You would do essentially the same as you did, except what you did on the inside you would do on the outside. Then come back with a few layers of glass on the inside. Then grind the outside flush, fill, and paint or gel coat. I would have also used either CSM and a cloth layer, or better yet just used a layer or 2 of 1708 on each side. I tend to over do things but it makes me feel good about it.
          1988 Sea Ray Seville 16 BRO w/1997 Mariner 115
          My build thread
          My upholstery thread
          • #6
            hey 109 mu buddy who was helping r/r my floors zipped right throught the hull with the cutoffdie grinder. hehehe actually funny now but he felt bad for days!! anyway i used 3 layers on the inside and nothing on the outside YET but since it is a 1/8 or less gash and it mostly filled from the resin and glass on the outside can i just fill the rest with gelcoat and be good to go? or should i mix some butter and fillin the last little bit then gelcoat .... in total it is 1/8 by 2 inch
