Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
What size closed rivets for aluminum boat
  • What size closed rivets for aluminum boat
    Hello, I have a 16' starecraft boat that I need to repair 6 rivets along the keel. The rivets broke when I hit a rather larger rock. The aluminum bent but is OK. Can anyone tell me what is the correct size rivet to use. I assume a 3/16 size hole will be made to take the old rivet out but how long should the rivet be? I assume I will need to fasten 3 pieces of aluminum together so the material might be .300 thick?? I'm not sure?? (keel, floor, support beam) all need to be riveted together? Also, can I use a hand held rivet gun? or do I need a more powerful gun.
    I am new to riveting so any help is appreciated. Thanks!
    Re: What size closed rivets for aluminum boat
    For solid rivets length you need the thickness of the material you are going to fasten plus 1.5 times the diameter of the rivet before bucking.
    1988 Sea Ray Seville 16 BRO w/1997 Mariner 115
    My build thread
    My upholstery thread
    • #3
      Thanks. I was thinking of using closed end rivets. I don't have access to inside. What size closed end should I use? Thanks
      • #4
        Use a drill bit to measure the diameter of the exsisting hole. I imagine it will be 1/4 or 3/16 of an inch diameter. You can get closed end pop rivets and install them with 3m5200..... you will probably want to get a 1/2" grip range.
        This is a great link to boat specifications http://boatspecs.iboats.com/
        Please, shop iboats first!!
        • #5
          Thanks for the reply. Can I use a std hand held gun for this?
          Back to Top
