I've recently purchased a 1993 Grumman fishing boat that has been very abused in the past. It's been left to sit in the rain for quite a few years and has had multiple owners it appears...
Going into it, I knew the deck was going to have to be replaced, and as I started the process of re-doing the floors, I was referred to these forums by a friend to help answer some questions.
After removing the first layer of rotten wood, I noticed that they had just put a second floor on top of the original. What a mess... Anyway, now that I've figured out how much work the floors are going to take and now how nice the boat is going to be when it's done, I've started to wonder about the transom.
The transom cap has been replaced in the past (not sure when), and they did a terrible job using very thin tin and then just sealed the heck out of it.
It seems that there is a lot of info on replacing the transom in these forums, but I couldn't find anything about if you can just buy replacement caps or if they need to be custom made? I also would like to get matching corners for the transom, any idea where to go about getting/ordering them?
Thanks for any info you can provide!
