Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
carpet adhesive on treated lumber
  • carpet adhesive on treated lumber
    I'm looking for a recomendation on what type of adhesive to use on treated lumber. Most I've seen (Henry's, Roberts) say not to use on treated lumbeer.
    Suggestions?
    Re: carpet adhesive on treated lumber
    Hello Russ..
    not only the ply compatible glue..but what does your carpet suggest. ?
    Most backed carpets I would suggest Dap Contact cement ( troweled ). some are too thin and use a spray glue ( like 3m trim adhesive in a spray ).
    NO MATTER what you use.. Dont be alone ..and wear a respo.
    last thing you need is to be overcome with fumes..bad bad stuff here....make you feel your hair grow ...
    YD. ... be safe m8 ( fume glues are nothing to mess with ! )
    Do your best and caulk the rest
    • #3
      I got mine at Lowe's. Outdoor carpet cement. Black can. I can't recall the name. If the wood is really wet it will take a long time to dry.
      and yeah, a good whiff and you'll have a headache for days.
      There are three types of people in this world:
      Those who understand math and those who don't.
      • #4
        I got mine at Lowes also. Mine was in a white gallon bucket. I used it on PT plywood that was still wet. Took a while to dry. Once it dries it holds very well. I used it on a small section of flooring in my boat. It was a quick fix using cheap carpet last summer. I decided to fix it right this spring. Had to use a grinding wheel to get the carpet off.
        • #5
          I build pontoon boats and we use sommething that looks and smells just like Elmers glue, it comes in a giant cube probably 80-100 gallons so I don't know a brand name but you can glue treated wood.
          I have used the trowel on outdoor carpet glue from Lowes/Menards on marine ply and it worked really well.
          What is up with all the Indiana boaters on here all of a sudden, never noticed alot of Hoosiers before.
          GO IRISH!!!!
          Back to Top
