Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
where to purchase marine plywood, and hatch door
  • where to purchase marine plywood, and hatch door
    Ok I need to know where to buy marine grade plywood. (local franchise hopefully) They don't carry it it Lowe's, or Home Depot here.
    Also I am wanting to get a hatch door for the bow glove box I will have made, if it is not too expensive. (the kind with a lock) You see these doors all the time in boats nowadays.
    Re: where to purchase marine plywood, and hatch door
    What will you be using this plywood for? The application may help you decide whether you really need marine plywood. It's likely that you don't.
    Sure...go ahead and laugh at my old aluminum boat. It's paid for!
    • #3
      If it turns out you do, you can get it usually from a "real" lumberyard.. not a Lowes or Home Depot type place, but look in your phone book or online for a local lumberyard or building supply center that is less retail oriented. They'll have better quality wood usually too.
      If they don't have it, they'll either know who will or they can order it in, usually cheaper than paying to have it shipped yourself.
      The only big box type store I've seen to carry it locally near me is Menards, and then only in their larger stores.
      Erik
      Edit: In Texas, it should be relatively easy to find a lumberyard that carries the stuff locally, since you at least have some ocean coastline on the state
      Sea Ray SRV-210 - Winter refit
      75-85 foot displacement hull trawler - gleam in my eye
      • #4
        I was able to find marine grade, pressure treated ply at a local boat repair shop. He's selling the 3/4" ply to me for $60/sheet. This particular grade is 7 ply and guaranteed for life. You might be able to find it yourself by doing a google search in your area for "boat repair" and then narrow down the results to an actual repair shop that specializes in glasss boat repair. I had pretty good luck and was able to find people that specialize in motors, upolstery, and repair.
        '76 Fiberform Custom 18
        Volvo AQ130D/280
        • #5
          Like CAT said, if we knew what you were doing with it we could head ya in a good direction. I have replaced one of the hatches on mine and just used oak. with the poly on it the wood will never see the moisture.
          sigpic "Spend a little money, save a lot of time"
          • #6
            This wood will go in for the transom. I was going to leave it, but it was recommended to me that I replace it. 1/4 sheet of marine grade plywood would be more than enough. This is for a 14 ft aluminum boat.
            • #7
              lumber yard for the wood. might need to ask around but someone close will have it. the hatch you can get in the iboats marine store probably and if not just check around online
              1986 Larson Senza V-175BR
              1977 Columbian Celebrity 14'
              New England Get Together.. Still getting ideas!! Come join in the fun!!
              http://forums.iboats.com/showthread....67&pagenumber=
              IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
              November 29 2010 RIP
              • #8
                Thanks. I will see if they have what I am talking about for a hatch on iboats. I had hoped to get one locally though.
                • #9
                  http://texasfishingforum.com/forums/...pics/3287175/1
                  This is the type hatch I meant, it is for a deck. I had hoped to be able to get one with a lock. I did not see anything like this on iboats.
                  • #10
                    do you want it to be aluminum or whatever that metal is or can it be plastic?
                    • #11
                      You can add a hatch without purchasing anything fancy. Doesn't need to have a full frame around it. Stainless steel piano hinge, build a box underneath with a lip for the door to rest on, and a simple collapsing marine latch. Carpet (or not), done!
                      1989 Starcraft 171S Select "Cap'n Crunch" / OMC Cobra 4.3 V6 / 432APRMED
                      If you're going to keep that OMC Cobra, please for the love of everything good in the world, get an OMC factory service manual. Not a Clymers, Not a SELOC. You can find them on eBay.
                      My boat repair website: http://transomfix.dcpolk.com
                      sigpic
                      • #12
                        I would prefer the aluminum. If it is too high, I won't get it though. It does look awful nice, a lot of fishing boats have them I noticed.
                        • #13
                          I wonder where to get a piano hinge. The box below is the bow of the boat. I plan to put a glove box area in there, with a small casting deck on top. That will hold my first aid kit, fire extinguisher, and stuff like that. I would like to be able to lock it too.
                          • #14
                            Google!
                            sigpic
                            • #15
                              I think the hatches in that thread you linked are assembled from aluminum frame, some panel pieces, and hinge and latch hardware... they don't look like they're a factory unit.
                              But if you want aluminum hatches, a couple good places to get them are here:
                              http://www.heatercraft.com/category.aspx?categoryID=36
                              and
                              www.greatlakesskipper.com
