weider1717
- Sep 2, 2008
- 315
Hey guys I have a new cut ski lift out center board ready to go in my boat, but first I want to put poly resin and fiberglass mat down.
I went to walmart and bought the "bondo" brand poly resin and some of their fiberglass mat. Think the bag said it covers 8ft? anyway..
anyway I am not sure of the correct procedure..do I coat the wood with the poly resin FIRST before I put any fiberglass mat down?
what is the sequence is my main question here.
lets say the proper thing to do is to coat the wood with the poly resin first before putting the fiberglass mat down. Do I allow that first coat to the wood to harden and set BEFORE I put the fiberglass mat down or while that coat is wet then lay down the fiberglass mat.
at that when the mat is down do you allow it and the under coat to dry before putting resin on top of the mat or do you lay the top coat of resin on the mat wihle the under coat is wet or dry or what.
I think you guys understand my question here, it's what is the proper sequence for this
thanks
thanks
