Re: Will this respirator work?
BE CAREFU!!!
for dust and regular organic vapors that will work fine if you keep it in a plastic bag between uses, etc...
However, the ONLY cartridge filter that has been tested with success against isocyanate-based sprayed paint is the 3m combination particulate and carbon cartridge set-up. The others that were tested against HMDI, TDI and MDI based paints ALL let some through, especially the carbon only filters (the aerosolized droplets of isocyanate make it through the carbon only filters).
Also, for isocyanayte based paints, if you can start to smell it, the cartridges are saturated and you are already WAY over the recommended exposure limits. The ONLY way to safely use filter cartridge-ased respirators for spraying isocyanate-based urethane paints is to use the cartridges once and then throw them away. This is the reason that they will never be recommended - people will get lazy and tight and not replace them... and potentially even die because of it...
rolling the above paints is not very risky at all... the vapor pressure of the isocyanates is very low in general...
