Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
is splitting a boat in half difficult ?
  • is splitting a boat in half difficult ?
    i am looking at a early 70s bomber fiberglass bassboat. it has been under a cover and not used since 1992. the floor seems to be in solid shape, but the transom is weak. threre isnt any major cracks in the top of the transom, but you can rock the engine and watch the transon give. also near the top of the transom you can give it a good squeeze by hand and see it give in. the boat is i believe a 16 foot with a 50 horse merc on it. the transom is sealed on the inside and out, and with the splashwell like it is, there isnt any good way to get to the transom to work on it. so i was wondering how difficult it is to remove the topside of the boat ? i figured if i could do it, that the wood in the transom will be exposed, and i could just remove it all from the top and slide in my new ply. i know this is going to be a lot of work, but i am good with resins and glass, and am very mechanically inclined. this seems like a awful lot to do on a old boat like this, but i would be getting the boat motor and trailer for close to nothing, the man parked it after having some engine work done and having it not run the next time he took it out.i figure if the motor isnt easily fixable,i can part it out .i also have available another 50 merc that i can pick up for $100.00 and the boat is set up inside just like what i am wanting.
    thanks
    sigpicJames M
    Diving in over my head
    Re: is splitting a boat in half difficult ?
    its easy......depending on the boat....it can be done in a few hours......
    and that is the proper way to do a transom
    read hull extension in progress....there is picks of the process in there
    The Hull Extension Thread
    great info on all aspects on boat building with detailed information.
    http://forums.iboats.com/showthread.php?t=234392
    IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
    IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
    November 29 2010 RIP
    • #3
      thanks oops
      sigpicJames M
      • #4
        read this: http://www.shareaproject.com/pages/p...,p,346,00.html
        FLORIDA GATORS
        TEBOW Country
        Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
        That is what these forums are for. Post your questions, in the appropriate Forum.
        • #5
          Originally posted by tashasdaddy View Post
          If you have any questions, feel free to PM me. One thing to keep in mind about pulling the top ( cap ) off your boat is that the sides are going to bow outward, so when you put the cap back on, you'll want help fitting it back on. I put mine on by myself last fall and it was a real bear to do singlehandedly. If you take the entire cap off, the easiest way to fit it back on is to start from the rear of the boat and work towards the bow...trust me on this....I did mine the opposite way.
          my thread here,My Shareproject page,Part 1,Part 2,Part 3,Part 4
          Official Tri Hull Club thread
          • #6
            after i remove the rubrail and all of the screws i can find holding the boat together, is there usually some type of glue or sealer that i will have to deal with before pulling it apart ?
            sigpicJames M
            • #7
              sometimes.
              FLORIDA GATORS
              TEBOW Country
              • #8
                thanks TD i am trying to gather all the info i can before i start on it
                sigpicJames M
                • #9
                  its very easy to figgure out when you get in there........
                  a small putty knife between the deck hull joint....and run the knife all the way around....(shoe box joint.......the cap fits like a lid of a shoe box)
                  in a flange joint.....there might be a layer of fiberglass on the inside.....flange joints are somewhat rare.
